Старый 05.07.2012, 16:11   #1
ax-erp: Iterate through all controls of a form
Источник: http://microsoft-dynamics-ax-erp.blo...s-of-form.html
Hi Christian
First, you could look at the SysSetupForm form and Class. This form and
class iterates through a form and displays its setup. It is quite advanced so
if you want a simpler but limited solution you could follow the approch that
I have sketched below
1. In you run() method, loop through the controls of your form. This can be
done using the line below
<span style="color: #333333; font-family: Verdana, Arial, Tahoma, Calibri, Geneva, sans-serif; font-size: 13px;">for(i=1 ; i
ax-erp: How to filter records in a form by code Blog bot DAX Blogs 0 13.06.2012 16:11
Часовой пояс GMT +3, время: 17:19.
