Старый 05.09.2012, 22:11   #1
sashanazarov: ID change in Dynamics AX data dictionary
Источник: http://sashanazarov.blogspot.com/201...ictionary.html
The other day we upgraded to Cumulative Update 3 for Dynamics AX 2012. After that we got some problems in the SqlDictionary table - several table and field IDs did not much those in the AOT anymore.
One of our developers found this post, which contained a job fixing such issues. We had to correct the job a bit, otherwise it failed when trying to process Views or update field IDs that had been "swapped" during upgrade (e.g. before: fieldId1 = 6001, fieldId2 = 6002; after installing CU3: fieldId1 = 6002, fieldId2 = 6001).
This is the final version of the job. I know the change violates DRY principle, but for an ad-hoc job it is probably OK :)
<span style="font-size: x-small;">static void fixTableAndFieldIds(Args _args)
Dictionary dictionary = new Dictionary();
SysDictTable dictTable;
DictField dictField;
TableId tableId;
FieldId fieldId;
SqlDictionary sqlDictionaryTable;
SqlDictionary sqlDictionaryField;
setPrefix("Update of data dictionary IDs");
tableId = dictionary.tableNext(0);
ttsbegin;
while (tableId)
dictTable = new SysDictTable(tableId);
setPrefix(dictTable.name());
if (!dictTable.isSystemTable() && !dictTable.isView())
//Finds table in SqlDictionary by name in AOT, if ID was changed.
//Empty field ID represents a table.
select sqlDictionaryTable
where sqlDictionaryTable.name == dictTable.name()
&& sqlDictionaryTable.fieldId == 0
&& sqlDictionaryTable.tabId != dictTable.id();
if (sqlDictionaryTable)
info(dictTable.name());
//Updates table ID in SqlDictionary
if (ReleaseUpdateDB::changeTableId(
sqlDictionaryTable.tabId,
dictTable.id(),
dictTable.name()))
info(strFmt("Table ID changed (%1 -> %2)", sqlDictionaryTable.tabId, dictTable.id()));
fieldId = dictTable.fieldNext(0);
//For all fields in table
while (fieldId)
dictField = dictTable.fieldObject(fieldId);
if (dictField.isSql() && !dictField.isSystem())
//Finds fields in SqlDictionary by name and compares IDs
select sqlDictionaryField
where sqlDictionaryField.tabId == dictTable.id()
&& sqlDictionaryField.name == dictField.name()
&& sqlDictionaryField.fieldId != 0
&& sqlDictionaryField.fieldId != dictField.id();
if (sqlDictionaryField)
//Updates field ID in SqlDictionary
if (ReleaseUpdateDB::changeFieldId(
dictTable.id(),
sqlDictionaryField.fieldId,
-dictField.id(),
dictTable.name(),
dictField.name()))
info(strFmt("Pre-update: Field %1 - ID changed (%2 -> %3)",
dictField.name(),
-dictField.id()));
fieldId = dictTable.fieldNext(fieldId);
while (fieldId)
&& sqlDictionaryField.fieldId <span style="color: #00007f;">
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 17.08.2012 03:27
Часовой пояс GMT +3, время: 21:14.
