Старый 08.09.2012, 08:32   #1
25,644 / 848 (80) +++++++
sumitsaxfactor: Remove a Financial Dimension Value
Источник: http://sumitsaxfactor.wordpress.com/...mension-value/
Here is a job that can help you remove or blank out a financial dimension.
Note the Dimensions before executing this job
Job
staticvoid sgxRemoveWorkerDimension(Args _args)
* We will Remove a worker dimension in this example
CustTable custTable = CustTable::find(‘CUS-00004′); //Customer Record containing Financial Dimension
DimensionSHA1Hash hash; //To store the calculated hash for DimensionAttributeValueSet
DimensionAttribute dimAttr; // Contains the financial dimensions records
DimensionAttributeValue dimAttrValue; // Contains used financial dimension values
DimensionAttributeValueSet dimAttrValueSet; //Contains default dimension records
DimensionAttributeValueSetItem dimAttrValueSetItem; //Contains individual records for default dimensions
DimensionAttributeSetItem dimAttrSetItem; // Contains the number of dimensions active for a account structure ledger
HashKey valueKeyHashArray[]; //To store the has key of dimension in question
Map dimAttrRecId, dimAttrStr; //To store the dimension attribute recid and dimension attribute value display value
Set dimAttrValueRecId;
SetEnumerator setEnum;
int dimAttrCount, i;
//Initialize the map to store the backing entity types
dimAttrRecId = new Map(Types::Int64, Types::Integer);
dimAttrValueRecId = new Set(Types::Int64);
dimAttrStr = new Map(Types::Int64, Types::String);
//Find all the active dimensions for current ledger except main account and store there
//backing entity type in the map
whileselect RecId from dimAttr
orderby Name
where dimAttr.Type != DimensionAttributeType::MainAccount
join RecId from dimAttrSetItem
where dimAttrSetItem.DimensionAttribute == dimAttr.RecId &&
dimAttrSetItem.DimensionAttributeSet == DimensionCache::getDimensionAttributeSetForLedger()
dimAttrCount++;
dimAttrRecId.insert(dimAttr.RecId, dimAttrCount);
//initialize hash key array to null
<span><font face="Consolas"><font size="2">for (i = 1<font color="#000000">; i
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension–Version 2 [AX 2012] Blog bot DAX Blogs 0 30.01.2012 17:11
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension Blog bot DAX Blogs 0 19.01.2012 13:11
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions [AX 2012] Blog bot DAX Blogs 0 18.01.2012 11:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 09.11.2010 19:04
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 23:23.
