Старый 15.09.2012, 08:43   #1
dynamicsaxbi: Overview: Drill-Thru Support in Reports
Источник: http://blogs.msdn.com/b/dynamicsaxbi...n-reports.aspx
Microsoft Dynamics AX 2012
WHAT IS DRILL THROUGH SUPPORT?
With regard to SSRS reports in Microsoft Dynamics AX 2012, drill-thru support is the ability to support end-user navigations using clickable hyperlinks embedded directly in the report content.
Supported URL targets:
  • Forms in the AX rich client
  • Enterprise Portal pages
  • Internet/intranet sites
  • SSRS reports
MULTIPLE CLIENT SUPPORT
The AX Reporting Framework is used to support both the rich client as well as the Enterprise Portal environment. AX Forms are accessed using references to Menu Items. The framework also takes care of determining the appropriate destination depending on the context of the report execution. SSRS Reports will direct users to an AX Form when rendered in the Report Viewer control and to an EP Web Part when rendered within the EP client.
LINK FORMATTING
Report developers are able to alter the textual formatting and styles used by report navigation links across all AX Reports directly in the report style templates. These settings are honored by the Auto Design templates and will be maintained when transitioning to a Precision Design.
MULTIPLE CONTEXT INDEXES
Most AX Forms rely on a single field reference to establish the navigation context. For instance, you can identify which Customer to high-light in the Customer Details Form using just the Customer Account. This is an example of context derived from a single index. However, there are objects that require multiple field references to establish the navigation context. The Main Account table is a perfect example since it requires both the Main Account ID in addition to the Ledger Chart Of Accounts ID to establish context for a single record.
To provide this flexibility, the AX Reporting Framework allows for a varying number of context arguments to facilitate navigation to an AX Form or EP Web Part.
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamicsaxbi: How To: Directing Reports to Email Blog bot DAX Blogs 0 10.03.2012 10:11
dynamicsaxbi: Understanding How Many SSRS Reports come with Dynamics AX 2012 Blog bot DAX Blogs 2 04.03.2011 17:50
DynamicsAxSCM: Arrival overview Blog bot DAX Blogs 0 29.11.2009 23:06
Часовой пояс GMT +3, время: 02:48.
