Старый 01.05.2013, 16:12   #1
emeadaxsupport: How to set up SEPA Credit transfers in AX2012
Источник: http://blogs.msdn.com/b/axsupport/ar...in-ax2012.aspx
The attached document provides a step by step description with screenshots on how to set up the SEPA Credit transfer in Dynamics AX 2012
emeadaxsupport: Processing Credit Cards in AX 2012 Blog bot DAX Blogs 0 07.11.2012 03:24
emeadaxsupport: Microsoft Dynamics AX 2012: How to set up Grid column width on fixed value Blog bot DAX Blogs 0 31.10.2012 22:12
emeadaxsupport: How to set up Dynamics AX 4.0 Reporting role on application with Turkish GLS installed and collation Turkish_CI_AS Blog bot DAX Blogs 0 04.08.2010 00:06
emeadaxsupport: How to set the number sequence for Global Address Book when virtual companies are used Blog bot DAX Blogs 0 24.08.2009 14:05
Часовой пояс GMT +3, время: 10:09.
