Старый 17.02.2014, 16:11   #1
atinkerersnotebook: Archive Excel Exports Automatically In SharePoint Document Libraries
Источник: http://atinkerersnotebook.com/2014/0...ent-libraries/
Originally posted on Dynamics AX Tip Of The Day:
When you export data from Excel, by default it creates a temporary export file locally on your workstation, although there is an option that you can use that will allow you to automatically archive the export to a default directory.  This has the added benefit that you are also able to archive the files then to SharePoint.  If you would like to make your exports sharable, or would just like to have a place to go to see all of the exports that you have done in the past, then this is a great option to configure.You’re not a data packrat if you do this…
View original
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
atinkerersnotebook: Using the Dynamics AX Excel Add-In Blog bot DAX Blogs 1 25.09.2013 07:11
atinkerersnotebook: Using Excel to Import Products & Services in Dynamics AX Blog bot DAX Blogs 0 19.07.2013 15:11
Часовой пояс GMT +3, время: 12:32.
