Старый 14.05.2014, 17:11   #1
kurthatlevik: Running Dynamics AX R3 on Azure
Источник: http://kurthatlevik.wordpress.com/20...x-r3-on-azure/
To install and use Dynamics AX R3 on Azure is easy to setup is ready within 15 minutes.
All you have to do is to log into https://lcs.dynamics.com/
Then create a project, and click on the “Cloud hosted environments(Beta)”
Then click on the “plus” to deploy the image, and give it a name.
Let it run for 15 minutes, and the image is now available in the Microsoft Azure portal.
Then Click on the “Connect” button, and you will receive a RDP-file you can use to log into the image.
PS!
Here is some small tips for improving performance:
  1. Change the power plan to High Performance
  2. Set performance options in the VM to “Best performance”
  3. Run index rebuild/re-organize on both data and model database, as described here.
  4. I also “pimped-up” my VM images with 8 CPU and 56 Gb Ram, to get the best possible performance.(But it cost!)
Congratulation you are now “certified” for deploying Azure demo images for Dynamics AX 2012 R3:
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2013 Update Rollup 2 Blog bot Dynamics CRM: Blogs 0 15.04.2014 01:15
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 12 Blog bot Dynamics CRM: Blogs 0 30.01.2013 01:11
Часовой пояс GMT +3, время: 08:30.
