Старый 25.06.2014, 05:22   #1
atinkerersnotebook: Set Default Parameter Values Into Posting Forms
Источник: http://atinkerersnotebook.com/2014/0...posting-forms/
Originally posted on Dynamics AX Tip Of The Day:
There are usually a lot of different configuration choices that you can make choose from when you are performing updates and postings within the Dynamics AX forms. But you probably only use one option on a daily basis. Rather than going in and changing the selection parameters every time you open up the form, Dynamics AX allows you to set the default values and from then on you will always have the right parameters in your form.
This is definitely a case of set it and forget it.
View original 119 more words
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
atinkerersnotebook: Configuring Lean Manufacturing in Dynamics AX 2012 Blog bot DAX Blogs 1 12.08.2013 00:15
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 14:48.
