Старый 11.09.2014, 15:11   #1
palleagermark: Normalization pattern for custom fields in separate table
Источник: http://www.agermark.com/2014/09/norm...-customer.html
When you need to add fields to standard tables, you can choose to add them to a new linked table rather than to the standard table.
If you do that, you might find the pattern for normalization for county/region fields useful.
Have a look at the White Paper "Adapting your code to table normalization for country/region fields in Microsoft Dynamics AX 2012 R2"
Pawan's Ax blog: How To Iterate all the fields of a table in Ax2012 using x++ code. Blog bot DAX Blogs 0 02.01.2014 22:11
Dynamics AX Sustained Engineering: Fields modifiedDateTime and modifiedBy on Table InventSum Blog bot DAX Blogs 0 30.12.2010 00:12
palleagermark: It is possible for users to edit the Item reference fields of sales order lines and purchase order lines. Blog bot DAX Blogs 0 17.02.2010 21:07
palleagermark: Use keyboard lookup in Product Builder enumerated fields Blog bot DAX Blogs 0 18.08.2009 23:06
axaptafreak: Getting new table fields into your form datasource Blog bot DAX Blogs 2 24.01.2008 22:51
Часовой пояс GMT +3, время: 08:41.
