Старый 25.03.2015, 18:11   #1
axforum blogs: Simple watch
Источник: http://axforum.info/forums/blog.php?b=8176
static void SimpleWatch(Args _args) { DEV_Global::startWatch(1); DEV_Global::startWatch(2); sleep(100); DEV_Global::stopWatch('Watch 1', 1); sleep(300); DEV_Global::stopWatch('Watch 2', 2); }
Код:
Watch 1: 00:00:00.1007452 Watch 2: 00:00:00.4087249
static public server void startWatch(int _idx = 1) { System.Diagnostics.Stopwatch watch; watch = new System.Diagnostics.Stopwatch(); watch.Start(); if (appl.globalCache().isSet(identifierStr(Stopwatch), _idx)) { appl.globalCache().remove(identifierStr(Stopwatch), _idx); info('Old watch has been reset.'); } appl.globalCache().set(identifierStr(Stopwatch), _idx, watch); }
static public server str stopWatch( TempStr _txt = 'Elapsed time', int _idx = 1, boolean _skipInfo = false) { System.Diagnostics.Stopwatch watch; System.TimeSpan elapsed; str ret; if (appl.globalCache().isSet(identifierStr(Stopwatch), _idx)) { watch = appl.globalCache().get(identifierStr(Stopwatch), _idx); appl.globalCache().remove(identifierStr(Stopwatch), _idx); } if (watch && watch.get_IsRunning()) { watch.Stop(); elapsed = watch.get_Elapsed(); ret = CLRInterop::getAnyTypeForObject(elapsed.ToString()); if (!_skipInfo) { info(strFmt('%1: %2', _txt, ret)); } } else { info('Watch is not running.'); } return ret; }
DynamicsAxSCM: How to support a case picking operation using wave containerization in AX2012R3 Blog bot DAX Blogs 0 19.11.2014 16:11
axmfg: Lean manufacturing: Picking activities and kanban line events Blog bot DAX Blogs 0 26.08.2014 21:13
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
crminthefield: Creating SSL Certificates for CRM Test Environment Blog bot Dynamics CRM: Blogs 0 10.12.2013 02:12
Microsoft Dynamics CRM Team Blog: Creating and Publishing a Web Portal to an Azure Cloud Service Blog bot Dynamics CRM: Blogs 0 17.04.2013 23:11
Часовой пояс GMT +3, время: 07:56.
