Старый 27.10.2015, 19:11   #1
sashanazarov: When fields lists don't work as expected
Источник: http://sashanazarov.blogspot.com/201...dont-work.html
Did you know that a field list in a single-record select-statement is not always beneficial in comparison to a select firstonly * from... (or a static find-method)?
The thing is, when a where-clause matches a unique index (in AX 2009 – a primary index), the AOS may find the complete record in the cache and return it. And if this is the very first call, it will pull the whole record anyway, in order to be able to cache it. This may be proved by debugging.
So please use find-methods where possible, because they are easier to read and maintain. And remember: a while select with a nested find-method call may actually perform better than a join – thanks to caching. Therefore do measure performance to confirm that your select-statement is the most optimal one.
DynamicsAxSCM: WHS Work List Blog bot DAX Blogs 0 19.06.2015 15:11
axmfg: Warehouse work for raw material picking split per route operation Blog bot DAX Blogs 0 22.09.2014 18:11
axmfg: Replacing work order types for production output in CU8 Blog bot DAX Blogs 0 12.09.2014 18:12
sashanazarov: Mandatory fields and table hierarchies Blog bot DAX Blogs 0 22.03.2013 16:11
Dave: Do and Don't Lists Blog bot DAX Blogs 2 05.03.2008 15:48
Часовой пояс GMT +3, время: 09:43.
