Старый 16.12.2015, 13:11   #1
25,644 / 848 (80) +++++++
mfp: X++ in AX7: Extension methods
Источник: http://blogs.msdn.com/b/mfp/archive/...n-methods.aspx
Have you ever experienced a Microsoft provided class or table missing that vital method that would just make your life easier? If so, you might have been tempted to add it yourself using overlayering. And you surely have paid the upgrade price!
You are about to be pleased. In AX7 X++ supports extension methods, similarly to C#.
Suppose we want to add a fullName method to the DirPersonName table. Here is how you do it, without touching the DirPersonName table. Create this new class:
static class MyDirPersonName_Extension
static public PersonName fullName(DirPersonName _person)
return strFmt('%1 %2 %3', _person.FirstName, _person.MiddleName, _person.LastName);
Things to remember:
  1. The class must be postfixed with "_extension".
  2. The class must be static.
  3. The extension methods must be static.
  4. The type of the first parameter determines which type is extended.
Now you can enjoy your extension method:
DirPersonName dirPersonName;
while select dirPersonName
info(dirPersonName.fullName());
Notice:
  1. When calling extension methods, you don't provide the first parameter – that gets inferred from the instance's type.
  2. If the extension method took any additional parameters – they (of course) needs to be provided.
  3. This doesn't break encapsulation. The extension method only has access to public fields and methods on the type.
THIS POST APPLIES TO MICROSOFT DYNAMICS AX7 TECHNICAL PREVIEW; IS PROVIDED AS-IS AND CONFERS NO RIGHTS.
mfp: X++ in AX7: Readonly keyword Blog bot DAX Blogs 3 15.12.2015 18:22
mfp: X++ in AX7: Client/Server keywords Blog bot DAX Blogs 23 15.12.2015 09:09
mfp: X++ in AX7: Static event subscription Blog bot DAX Blogs 0 11.12.2015 11:11
mfp: X++ in AX7: The var keyword Blog bot DAX Blogs 43 04.12.2015 10:19
mfp: X++ in AX7 Blog bot DAX Blogs 0 02.12.2015 22:13
Часовой пояс GMT +3, время: 07:40.
