Старый 26.04.2016, 03:42   #1
organicax: Vendor – Chain
Источник: https://organicax.com/2016/04/25/vendor-chain/
In a previous post we had a look at different patterns in vendor setup. When looking at different ways to model and report on your suppliers you could look at using the chain field if you want a simple linking between the vendors.
It’s a self definable field meaning you can make up the name and description so if you are doing to use it heavily then you might want to agree on a naming convention for your organization. This field is shared with the customer record so if you are going to use chain for both customers and suppliers then you want to be careful about how you create the names to make them meaningful.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Accounts receivable, Procurement and sourcing
organicax: AR Parameters – Fulfillment rate, Fulfillment violation messages Blog bot DAX Blogs 0 11.04.2016 19:12
organicax: Sales order backorder lines lists. Blog bot DAX Blogs 0 06.04.2016 00:15
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
organicax: AX R3 Warehouse in manufacturing – end to end basic flow. Blog bot DAX Blogs 0 09.03.2016 16:11
organicax: Purchase items using auto batch numbers – wms Blog bot DAX Blogs 0 08.03.2016 21:16
Часовой пояс GMT +3, время: 08:45.
