Старый 05.07.2007, 08:27   #1
smoyk is offline
smoyk
Я создал таблицу, а сервер создал на нее ккакойто непонятный триггер:
Код:
CREATE TRIGGER "dbo"."УПРАВЛ_ Чибис$AutoOrder_TG" ON "dbo"."УПРАВЛ_ Чибис$AutoOrder" FOR DELETE, INSERT, UPDATE AS
SET NOCOUNT ON
DECLARE @del_count int
DECLARE @ins_count int
SELECT  @del_count = count(*) FROM deleted
SELECT  @ins_count = count(*) FROM inserted
IF (@del_count > 0 AND @ins_count = 0) OR UPDATE("id") OR UPDATE("ItemCode") OR UPDATE("LocationOrder")
BEGIN
	DECLARE @v0 INTEGER
	DECLARE @v1 VARCHAR(30)
	DECLARE @v2 DECIMAL(38,20)
	IF @del_count > 0
	BEGIN
		IF @ins_count > 0
		BEGIN
			DECLARE deleted_cursor CURSOR LOCAL FOR
			SELECT l."LocationOrder", l."id", l."LocationOrder" FROM deleted AS l LEFT OUTER JOIN inserted AS r ON (
			l."id" = r."id" AND
			l."ItemCode" = r."ItemCode"
			) WHERE
			r."id" IS NULL OR
			r."ItemCode" IS NULL OR
			l."LocationOrder" <> r."LocationOrder" OR
			OPEN deleted_cursor
			FETCH NEXT FROM deleted_cursor
			INTO @v2, @v0, @v2
			WHILE @@FETCH_STATUS = 0
			BEGIN
				IF (@v2 <> 0)
				BEGIN
					UPDATE "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) SET "s5" = "s5" - @v2 WHERE bucket = 1 AND "f5" = @v2 AND "f1" = 0
					IF @@rowcount = 0
					BEGIN
						INSERT INTO "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) VALUES (1, @v2, 0, -@v2)
					END
					UPDATE "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) SET "s5" = "s5" - @v2 WHERE bucket = 2 AND "f5" = @v2 AND "f1" = @v0
					IF @@rowcount = 0
					BEGIN
						INSERT INTO "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) VALUES (2, @v2, @v0, -@v2)
					END
				END
				INTO @v2, @v0, @v2
			END
			CLOSE deleted_cursor
			DEALLOCATE deleted_cursor
		END
		ELSE
		BEGIN
			SELECT "id", "ItemCode", "LocationOrder" FROM deleted
			OPEN deleted_cursor
			INTO @v0, @v1, @v2
			BEGIN
				IF (@v2 <> 0)
				BEGIN
					IF @@rowcount = 0
					BEGIN
					END
					IF @@rowcount = 0
					BEGIN
					END
				END
				INTO @v0, @v1, @v2
			END
		END
	END
	IF @ins_count > 0
	BEGIN
		IF @del_count > 0
		BEGIN
			DECLARE inserted_cursor CURSOR LOCAL FOR
			SELECT l."LocationOrder", l."id", l."LocationOrder" FROM inserted AS l LEFT OUTER JOIN deleted AS r ON (
			l."id" = r."id" AND
			) WHERE
			r."id" IS NULL OR
			OPEN inserted_cursor
			FETCH NEXT FROM inserted_cursor
			INTO @v2, @v0, @v2
			BEGIN
				IF (@v2 <> 0)
				BEGIN
					UPDATE "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) SET "s5" = "s5" + @v2 WHERE bucket = 1 AND "f5" = @v2 AND "f1" = 0
					IF @@rowcount = 0
					BEGIN
						INSERT INTO "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) VALUES (1, @v2, 0, @v2)
					END
					UPDATE "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) SET "s5" = "s5" + @v2 WHERE bucket = 2 AND "f5" = @v2 AND "f1" = @v0
					IF @@rowcount = 0
					BEGIN
						INSERT INTO "УПРАВЛ_ Чибис$50097$0" WITH (SERIALIZABLE) VALUES (2, @v2, @v0, @v2)
					END
				END
				INTO @v2, @v0, @v2
			END
			CLOSE inserted_cursor
			DEALLOCATE inserted_cursor
		END
		ELSE
		BEGIN
			SELECT "id", "ItemCode", "LocationOrder" FROM inserted
			INTO @v0, @v1, @v2
			BEGIN
				IF (@v2 <> 0)
				BEGIN
					IF @@rowcount = 0
					BEGIN
					END
					IF @@rowcount = 0
					BEGIN
					END
				END
				INTO @v0, @v1, @v2
			END
		END
	END
END
Сорри Черт ногу сломит. Я примерно(!) вкурил, что ведется лог всех действий/модификаций с моей таблицей и результаты пишутся в таблицу "УПРАВЛ_ Чибис$50097". Вроде бы. Так на кой это надо? И откуда это взялось? На других таблицах, которые я создавал таких триггеров нет. Да и на стандартных их нет.
Подскажите пожалуста, что с этим делать?
Часовой пояс GMT +3, время: 04:03.
