Старый 19.12.2007, 15:30   #1
25,644 / 848 (80) +++++++
The Job Queue is handling the order of batch jobs and code units that are setup to run at a given time. The application server reads from the job queue and determines what job to run next. Several parameters can be set up to determine this. Prerequisites Before you can setup and execute a job queue you will need to: 1. Install Microsoft Dynamics NAV 5.0 2. Install Microsoft Dynamics NAV Application Server a. Make sure that the NAV user is registered in NAV and on the SQL Server, if SQL Server is...(read more)
Подробнее... http://dynamicsuser.net/blogs/navsustatine...cs-nav-5-0.aspx
Часовой пояс GMT +3, время: 14:17.
