Старый 14.10.2008, 12:10   #1
http://www.mibuso.com/dlinfo.asp?FileID=950 (NAV W1 5.0 SP1)
В папке архива dynamicsnavw150sp1clientDoc есть полезные .pdf документы.
В частности w1w1ism.pdf
(Installation & System Management: C/SIDE Database Server for Microsoft DynamicsTM NAV)
Там есть краткая информация (страницы 148 - 154) по 'железу'.
Выдержка
6.1 Checklist for Optimizing Hardware
There are many factors that must be considered if you want to get the best
performance out of your enterprise business solution. It is not possible to define a
single optimal solution, because there are many individual requirements that have to
be considered. The information in this chapter will help you assess your requirements,
and select the appropriate hardware and software. Once you have established the
network, you can optimize the system by tuning the various parameters described in
the following sections.
The following table can be used as a checklist when you optimize your installation:
Item Recommendation
Hard Disk As fast as possible
Controller Fast, secure and battery backed, able to control several hard disks simultaneously
RAID RAID 1 is preferable
Memory As much as possible, of ECC type or with parity
Network Adapter As fast as possible
CPU As fast as possible
Network Protocol TCPS
Подробнее... http://blogs.technet.com/alexef/archive/20...ngHardware.aspx
Часовой пояс GMT +3, время: 06:47.
