Старый 25.08.2009, 22:34   #1
The query below combines these three queries into one:
Index Usage Query
Recent Bocking History
Table Information Query
It can be used to just see the number of records in each table. But also by just changing "ORDER BY", it can be used to see which index cause most blocking / wait time / updates or locks. Or to compare Index Updates with Index Reads to get an idea of cost versus benefit for each index for the purpose of index tuning.
So in short, one query gives you:
- Index / Table Information
- Index usage (benefits and costs information for each index)
- Index locks, blocks, wait time and updates per read (cost/benefit).
The query must be run in your NAV database. It will create a table called z_IUQ2_Temp_Index_Keys and use various Dynamic Management Views to collect information for each index into this table. First time you run it, or if you want to refresh data, you must run the whole query which may take up to a minute of two for each company in the database. After that if you just want to change sorting / get the results again, then you only need to run the last part of the query, beginning with:
-- Select results
The last lines suggest various "ORDER BY"s that might be useful to enable instead of the default one, which is by Table Name.
Lars Lohndorf-Larsen
Microsoft Dynamics UK
Microsoft Customer Service and Support (CSS) EMEA
These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use.
--use NavisionDatabase
IFOBJECT_ID('z_IUQ2_Temp_Index_Keys','U')ISNOTNULL
DROPTABLE z_IUQ2_Temp_Index_Keys;
-- Generate list of indexes with key list
createtable z_IUQ2_Temp_Index_Keys(
[l1] [int] NOTNULL,
[F_Obj_ID] [int] NOTNULL,
[F_Schema_Name] [nvarchar] (128)NULL,
[F_Table_Name] [nvarchar] (128)NOTNULL,
[F_Row_Count] [int] NULL,
[F_Reserved] [int] NULL,
[F_Data] [int] NULL,
[F_Index_Size] [int] NULL,
[F_UnUsed] [int] NULL,
[F_Index_Name] [nvarchar] (128)NOTNULL,
[F_Index_ID] [int] NOTNULL,
[F_Column_Name] [nvarchar] (128)NOTNULL,
[F_User_Updates] [int] NULL,
[F_User_Reads] [int] NULL,
[F_Locks] [int] NULL,
[F_Blocks] [int] NULL,
[F_Block_Wait_Time] [int] NULL,
[F_Last_Used] [datetime] NULL,
[F_Index_Type] [nvarchar] (128)NOTNULL,
[F_Index_Column_ID] [int] NOTNULL,
[F_Last_Seek] [datetime] NULL,
[F_Last_Scan] [datetime] NULL,
[F_Last_Lookup] [datetime] NULL,
[Index_Key_List] [nvarchar] (MAX)NULL
go
CREATENONCLUSTEREDINDEX [Object_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys]
([F_Obj_ID] ASC
go
CREATENONCLUSTEREDINDEX [Index_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys]
([F_Index_ID] ASC
go
CREATENONCLUSTEREDINDEX [RowCount_ID_Index] ON [dbo].[z_IUQ2_Temp_Index_Keys]
([F_Row_Count] ASC
go
insertinto
SELECT
(row_number()over(orderby a3.name, a2.name))%2 as l1,
a1.object_id,
a3.name AS [schemaname],
a2.name AS [tablename],
a1.rows as row_count,
a1.reserved +ISNULL(a4.reserved,0))* 8 AS reserved,
a1
.data * 8 AS data,
CASEWHEN(a1.used +ISNULL(a4.used,0))> a1.data THEN(a1.used +ISNULL(a4.used,0))- a1.data ELSE 0 END)* 8 AS index_size,
CASEWHEN(a1.reserved +ISNULL(a4.reserved,0))> a1.used THEN(a1.reserved +ISNULL(a4.reserved,0))- a1.used ELSE 0 END)* 8 AS unused,
-- Index Description
SI.name,
SI.Index_ID,
index_col(object_name(SIC.object_id),SIC.index_id,SIC.Index_Column_ID),
-- Index Stats
US.user_updates,
US.user_seeks + US.user_scans + US.user_lookups User_Reads,
-- Index blocks
IStats.row_lock_count + IStats.page_lock_count ,
IStats.row_lock_wait_count + IStats.page_lock_wait_count,
IStats.row_lock_wait_in_ms + IStats.page_lock_wait_in_ms,
-- Dates
case
when
(ISNULL(US.last_user_seek,'00:00:00.000')>=ISNULL(US.last_user_scan,'00:00:00.000'))and(ISNULL(US.last_user_seek,'00:00:00.000')>=ISNULL(US.last_user_lookup,'00:00:00.000'))then US.last_user_seek
when(ISNULL(US.last_user_scan,'00:00:00.000')>=ISNULL(US.last_user_seek,'00:00:00.000'))and(ISNULL(US.last_user_scan,'00:00:00.000')>=ISNULL(US.last_user_lookup,'00:00:00.000'))then US.last_user_scan
else US.last_user_lookup
endas Last_Used_For_Reads,
SI.type_desc,
SIC.index_column_id,
US.last_user_seek,
US.last_user_scan,
FROM
(SELECT
ps
.object_id,
SUM(
CASE
WHEN
(ps.index_id < 2)THEN row_count
ELSE 0
END
)AS [rows],
SUM(ps.reserved_page_count)AS reserved,
SUM(
CASE
WHEN
(ps.index_id < 2)THEN(ps.in_row_data_page_count + ps.lob_used_page_count + ps.row_overflow_used_page_count)
ELSE(ps.lob_used_page_count + ps.row_overflow_used_page_count)
END
)AS data,
SUM(ps.used_page_count)AS used
FROMsys.dm_db_partition_stats ps
GROUPBY ps.object_id)AS a1
LEFTOUTERJOIN
(SELECT
it
.parent_id,
INNERJOINsys.internal_tables it ON(it.object_id= ps.object_id)
WHERE it.internal_type IN(202,204)
GROUPBY it.parent_id)AS a4 ON(a4.parent_id = a1.object_id)
INNER
JOINsys.all_objects a2 ON( a1.object_id= a2.object_id)
INNERJOINsys.schemas a3 ON(a2.schema_id= a3.schema_id)
inner
joinsys.indexes SI ON(SI.object_id= a1."object_id")
inner
joinsys.index_columns SIC ON(SIC.object_id= SI.object_idand SIC.index_id = SI.index_id)
left
outerjoinsys.dm_db_index_usage_stats US ON(US.object_id= SI.object_idand US.index_id = SI.index_id and US.database_id =db_id())
left
outerjoin sys.dm_db_index_operational_stats(NULL,NULL,NULL,NULL) IStats ON(IStats.object_id= SI.object_idand IStats.index_id = SI.index_id and IStats.database_id =db_id())
WHERE a2.type <> N'S'and a2.type <> N'IT'
orderby row_count desc
go
-- Populate key string
declare IndexCursor cursorfor
select
F_Obj_ID, F_Index_ID from z_IUQ2_Temp_Index_Keys
forupdateof Index_Key_List
declare @objID int
declare
@IndID int
declare
@KeyString VARCHAR(MAX)
set @KeyString =NULL
open IndexCursor
setnocounton
fetch
nextfrom IndexCursor into @ObjID, @IndID
while@@fetch_status= 0 begin
set
@KeyString =''
select @KeyString =COALESCE(@KeyString,'')+ F_Column_Name +', '
where F_Obj_ID = @ObjID and F_Index_ID = @IndID
ORDERBY F_Index_ID, F_Index_Column_ID
set @KeyString =LEFT(@KeyString,LEN(@KeyString)-2)
update z_IUQ2_Temp_Index_Keys
set Index_Key_List = @KeyString
wherecurrentof IndexCursor
fetchnextfrom IndexCursor into @ObjID, @IndID
end;
close IndexCursor
deallocate IndexCursor
go
-- clean up table to one line per index
deletefrom z_IUQ2_Temp_Index_Keys
where [F_Index_Column_ID] > 1
go
-- Select results
select
[F_Table_Name] TableName,
[F_Row_Count] No_Of_Records,
[F_Data] Data_Size,
[F_Index_Size] Index_Size,
[F_Index_Name] Index_Name,
[F_User_Updates] Index_Updates,
[F_User_Reads] Index_Reads,
case
when
F_User_Reads = 0 then F_User_Updates
else F_User_Updates / F_User_Reads
endas Updates_Per_Read,
[F_Locks] Locks,
[F_Blocks] Blocks,
[F_Block_Wait_Time] Block_Wait_Time,
[F_Last_Used] Index_Last_Used,
[F_Index_Type] Index_Type,
[Index_Key_List] Index_Fields
--order by F_Row_Count desc, F_Table_Name, [F_Index_ID]
--order by F_User_Updates desc
--order by Blocks desc
--order by Block_Wait_Time desc
--order by Updates_Per_Read desc
orderby F_Table_Name
Читать дальше
Часовой пояс GMT +3, время: 15:23.
