|  27.10.2011, 04:14 | #1 |
| Участник | Microsoft Dynamics CRM Team Blog: CRM 2011 Charts – Charting on Related Records
			Источник: http://blogs.msdn.com/b/crm/archive/...-records1.aspx ============== This blog demonstrates how to create a chart from data in the current entity alongside data from related entities. Let’s take the following scenario: A Not For Profit Organization is using CRM 2011 to track the pledges and donations made by their donors. Each pledge a donor makes has a Pledge Amount and will have 1 to * donations associated to it. Each Donation has a Cash-Value and a Status. The Status will have one of the following values: Outstanding, Processing, or Collected. The CRM user that is responsible to manage the pledges for a given cause needs to be able to quickly see the status of a given pledge i.e. the original amount of the pledge and the amount collected. One possibility is to show the following chart in the Pledge form:   where:
 To create this chart and display it in the Pledge form, do the following: 1. Go to Settings > Customizations > Customize the System. 2. Create a Pledge entity with the field ‘Pledge Amount’ and a Donation entity with the fields ‘Cash-Value’ and ‘Status’.  3. Open the Donation entity 4. Create a new bar chart 5. Create a series for the field Cash Value.  6. Open the Pledge main form 7. Add a One Column Section 8. Insert a Sub-Grid. Enter the unique Name and Label. Select the entity (Donations) and the default View. Also check the box ‘Show Chart Only’ in order to hide the sub-grid.  9. In the formatting tab, set the number of rows to 12  10. Save, Close, and Publish all the customizations 11. Open a Pledge form 12. You will see the following chart.  13. Add a Global OptionSet in order to be able to change the legends’ labels
  14. Now we have to manually modify the chart. 15. Export the chart.
  16. Open in your favorite XML editor or notepad 17. Replace the generated with the following:
 24. Open a Pledge entity. Final result  Summary: We have showed you how to manually modify CRM 2011 charts in order to:
 “CRM 2011 Charts – Know the Real Potential”, Part 1 and Part 2. Christian J. Betrisey Here is the full chart XML that we modified in this example: {AB00D3AF-49E9-E011-B89B-00155DA96A01} Pledge Status by Amount new_donation false Источник: http://blogs.msdn.com/b/crm/archive/...-records1.aspx
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
