Старый 12.05.2016, 20:14   #1
organicax: WMS Menu – movement
Источник: https://organicax.com/2016/05/11/wms-menu-movement/
If you want to adjust inventory when you are using the advanced warehouse in AX you have a few options. Which one you choose will depend on your proceses for example is the person doing the movement physically moving stock at the same time or do you want someone to request the movement and then that is done at a later time. If you want to action the movement now then you can use the movement menu item.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Warehouse management
organicax: Movement by template – create movement Blog bot DAX Blogs 0 12.05.2016 20:14
organicax: WMS menu – movement by template Blog bot DAX Blogs 0 12.05.2016 20:14
organicax: WMS Mobile device menu – Display batch disposition codes Blog bot DAX Blogs 0 10.05.2016 17:11
organicax: WMS mobile device menu – Display disposition code Blog bot DAX Blogs 0 10.05.2016 17:11
atinkerersnotebook: Creating One Master Menu to Get Just What You Need Blog bot DAX Blogs 0 24.01.2015 16:16
Часовой пояс GMT +3, время: 12:00.
