Старый 20.09.2016, 03:29   #1
emeadaxsupport: CSS Global support incident closure procedure for AX2012 cases involving external hotfix release
Источник: https://blogs.msdn.microsoft.com/axs...otfix-release/
Process: Support case will be archived for AX2012 incidents involving a hotfix at the time bug information is available in Lifecycle Services (LCS) Example: AX2012 support case created Case is researched and found a code change is required by Microsoft Hotfix request is created Hotfix request is triaged and accepted, hotfix request is an in... Read more
waldo: NAV 2016: All Published Events Blog bot NAV: Blogs 0 30.05.2016 15:11
emeadaxsupport: Cloud-powered support – logging support incident for AX 2012 Blog bot DAX Blogs 0 28.04.2016 19:13
emeadaxsupport: Protected: Cloud-powered support – logging support incident for AX 2012 Blog bot DAX Blogs 0 26.04.2016 10:11
emeadaxsupport: Connecting Retail Components on an External Computer to the Microsoft Dynamics AX R3 Azure Lifecycle Services Demo Virtual Machine Blog bot DAX Blogs 0 28.06.2014 00:13
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
Часовой пояс GMT +3, время: 11:25.
