Старый 01.10.2016, 04:15   #1
25,644 / 848 (80) +++++++
dynamicsaxhints: The power of firstOnly keyword
Источник: http://dynamicsaxhints.blogspot.com/...y-keyword.html
Sometimes only one record from a table is required, but firstOnly keyword is not used by a developer. For example:
select AccountNum from custTable
where custTable.CustGroup == '10';
if (custTable.AccountNum)
What difference does it make?
Problem description
Compare select statements with and without firstOnly keyword.
Hints
Use SQL Server Profiler for analysis and trace RPC:Starting and RPC:Completed events:
Solution
The first test is the select statement with firstOnly keyword.
RPC:Starting event is below:
declare @p1 int
set @p1=NULL
declare @p2 int
set @p2=0
declare @p5 int
set @p5=28688
declare @p6 int
set @p6=8193
declare @p7 int
set @p7=2
exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT TOP 1 T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10'
select @p1, @p2, @p5, @p6, @p7
The most interesting parameter here is @p7. It is the number of fetch buffer rows (more details are on msdn and blog posts). I do not know why 2 records are requested, but based on RPC:Completed event only 1 record is fetched:
declare @p1 int
set @p1=1073741872
declare @p2 int
set @p2=180150427
declare @p5 int
set @p5=16
declare @p6 int
set @p6=1
declare @p7 int
set @p7=1
The second test is the select statement without firstOnly keyword.
declare @p1 int
set @p1=NULL
declare @p2 int
set @p2=0
declare @p5 int
set @p5=28688
declare @p6 int
set @p6=8193
declare @p7 int
set @p7=10
exec sp_cursorprepexec @p1 output,@p2 output,N'@P1 bigint,@P2 nvarchar(5),@P3 nvarchar(11)',N'SELECT T1.ACCOUNTNUM,T1.RECID FROM CUSTTABLE T1 WHERE (((PARTITION=@P1) AND (DATAAREAID=@P2)) AND (CUSTGROUP=@P3))',@p5 output,@p6 output,@p7 output,5637144576,N'usmf',N'10'
RPC:Completed event:
declare @p1 int
set @p1=1073741868
declare @p2 int
set @p2=180150467
declare @p5 int
set @p5=16
declare @p6 int
set @p6=1
declare @p7 int
set @p7=10
It means that 10 records are fetched into buffer instead of 1 record required in X++ code.
Why?
It is specifics of a cursor statement. In X++ it is possible to use next statement after a select statement to fetch an additional record.
Why 10?
The default is 20 rows, but the actual value is calculated as Maximum Buffer Size / Row Length.
Conclusion
It seems to be not a big deal, but small problems usually escalate. Using firstOnly keyword definitely improves performance.
dynamicsaxhints: Query datasource FirstOnly property Blog bot DAX Blogs 0 22.03.2016 09:11
axsa: Power BI and Dynamics AX: Part 1: Introduction Blog bot DAX Blogs 0 18.02.2015 18:11
atinkerersnotebook: Using Power BI to Visualize Customer Saturation Blog bot DAX Blogs 1 07.08.2013 08:11
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
Часовой пояс GMT +3, время: 04:02.
