Старый 14.10.2016, 19:11   #1
organicax: Route re-use with different resource for specific operations
Источник: https://organicax.com/2016/10/14/rou...ic-operations/
In a previous post we had a look at route re-use which can save time setting up data. Let’s say you have commonality with the number of operations that the products need to go through but in one operation you might use a different resource. For example you have multiple stamping machines that have die in them to punch a different pattern of holes for different models of products. You can setup this up in AX with an operation relationship to the different products.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control
organicax: Route feasibility error when resource not setup correctly Blog bot DAX Blogs 0 12.10.2016 19:12
organicax: Operation at different steps in a route with different resources Blog bot DAX Blogs 0 30.09.2016 22:13
organicax: Gantt charts for reviewing resource work Blog bot DAX Blogs 0 29.09.2016 04:27
emeadaxsupport: When you create a route card journal the resource is not defaulting as the resource group that was listed as the resource requirement. Blog bot DAX Blogs 0 10.08.2016 02:11
DynamicsAxSCM: Using route schedules in TMS with CU10 Blog bot DAX Blogs 0 11.12.2015 17:11
Часовой пояс GMT +3, время: 12:37.
