Старый 24.10.2016, 17:11   #1
organicax: Vendor invoice approved by purchase order preparer modification
Источник: https://organicax.com/2016/10/24/ven...-modification/
In a previous post we had a look at the walk through using a new participant provider for the vendor invoice workflow. In this overview we’ll have a look at the objects we modified to make this work.
It is work following a step by step example of creating a participant provider which you can follow in this post.
Here is a quick overview.
AX2012 R3 CU11
If you want a copy of the XPO for the sample code you can find it on my one drive.
https://1drv.ms/u/s!AjyKH96OSFD9gRCdwNGk7lrwlxS1
Cheers
Lachlan
Filed under: Accounts payable
organicax: Vendor invoice line approved by purchase order line requester modification Blog bot DAX Blogs 0 24.10.2016 17:11
organicax: Vendor invoice approved by purchase order preparer Blog bot DAX Blogs 0 24.10.2016 11:11
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
Часовой пояс GMT +3, время: 18:50.
