Старый 24.10.2016, 23:11   #1
organicax: Can’t see a category on purchase requisitions but can on purchase order
Источник: https://organicax.com/2016/10/24/can...urchase-order/
One of the benefits of the procurement module in AX is the policies. These parameters allow you to control what happens in different processes. If you have just setup a new category and you can see it when you fill in a purchase order line but you can’t see it when you put in a requisition line then likely you need to review the category access policy rule that you can find in the purchasing policy.
Here is a quick overview.
AX2012 R2 CU11
Cheers
Lachlan
Filed under: Procurement and sourcing
organicax: Creating a category based purchase order in AX7 Blog bot DAX Blogs 0 01.10.2016 04:15
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
dynamicsaxtraining: Purchase Blog bot DAX Blogs 0 11.03.2012 05:25
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
Часовой пояс GMT +3, время: 21:09.
