Старый 31.10.2016, 09:11   #1
25,644 / 848 (80) +++++++
organicax: Quick import export
Источник: https://organicax.com/2016/10/30/quick-import-export/
If you are looking for a quick way to dump out some data from AX and you have a current CU then you will find the quick import export. This allows you to use a sample file based on the entity you want to export from. It will save you creating a processing group, although you have the option of saving a processing group.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Data migration
DIXF. Data Import Export Framework пошаговые руководства в картинках demoded DAX: Функционал 0 23.09.2015 01:01
emeadaxsupport: Importing a General Journal using Data Import/Export Framework AX 2012 Blog bot DAX Blogs 0 17.07.2014 20:12
kurthatlevik: Import/Export: Reinventing the wheel Blog bot DAX Blogs 0 27.12.2013 18:11
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework standalone version for AX 2012 R2 without installing full CU7 Blog bot DAX Blogs 0 04.12.2013 04:13
NAV Team: How to: Enable Import/Export of Bank or Payroll Files Using the Data Exchange Framework Blog bot Dynamics CRM: Blogs 0 18.10.2013 02:33
Часовой пояс GMT +3, время: 09:52.
