Старый 06.09.2017, 13:11   #1
palleagermark: Important caveat with the "Chain of command" (CoC) feature
Источник: http://www.agermark.com/2017/09/impo...f-command.html
If you use CoC with the July 2017 application release, you need to compile and deploy the standard models you eventually use CoC with. The reason being that the standard models are compiled with Update 8 which didn't have CoC.
This is a temporary inconvenience, and will not be necessary after the "Autum" release.
So, if you write ISV/VAR solutions, you might want to postpone usage of CoC for anything you release before the "Autum" release.
chain of command
emeadaxsupport: Error when upgrading to AX 2012 Feature Pack: The UPDATE statement conflicted with the FOREIGN KEY constraint "FK_ModelElementData_HasModelId_LayerId" Blog bot DAX Blogs 0 20.07.2012 00:11
palleagermark: "Microsoft Dynamics AX 2012 Development Cookbook" review Blog bot DAX Blogs 0 05.06.2012 18:12
Platform updates overview - 3.70.B - NAV2009 R2 Blog bot Dynamics CRM: Blogs 0 07.02.2011 22:06
Часовой пояс GMT +3, время: 01:00.
