Старый 28.06.2018, 15:11   #1
25,644 / 848 (80) +++++++
dynamicsnavax: Testing #MSDyn365FO Odata with Postman
Источник: http://dynamicsnavax.blogspot.com/20...h-postman.html
Last year I posted on using Postman. Things have changed since then and I need to update.
http://dynamicsnavax.blogspot.com/20...b-service.html
There is a good article that Microsoft has written which I followed without any issues.
https://docs.microsoft.com/en-us/dyn...#prerequisites
Below are some screenshot incase you are a visual person like me.
In the environment set ups. It should looks something like this.
When you run it, you should get a response.
Once you got the token. You are good to go with your messages.
Below is the same example from the blog post.
You run into any problems, click on the console icon at the bottom. Should give you a bit more information.
If you get a 401 error. It is usually a typo. Make sure you got the spaces and backslashes correct. One simple character can drive you crazy.
d365o, web service
dynamicsnavax: Import document handling (attachment) files #MSDyn365FO Blog bot DAX Blogs 0 07.06.2018 10:11
dynamicsnavax: Add a new starting worker for workflow hierarchy approval #MSDyn365FO Blog bot DAX Blogs 0 13.04.2018 09:11
dynamicsnavax: Add Spending/Approval limit to Purchase Order Workflow #MSDyn365FO Blog bot DAX Blogs 0 01.04.2018 09:12
axtoday: Testing Dynamics 365 for Operation Recurring Integrations with Postman Blog bot DAX Blogs 0 23.10.2017 20:13
Часовой пояс GMT +3, время: 09:43.
