Старый 14.08.2018, 08:11   #1
daxmusings: Query Functions: SysQueryRangeUtil Extensions
Источник: http://feedproxy.google.com/~r/Dynam...rangeutil.html
Now that overlayering is a thing of the past, how does one add methods to SysQueryRangeUtil as explained in my old post from back in 2013?
Simple. Create your own class, name it whatever you want. Add a static method as described in the old post. The only difference is that you just put an attribute on top of it indicating that it's a query range utility method... So the method used in the old post, would now just look like this:
[QueryRangeFunctionAttribute()]
public static str customerTest(int _choice = 1)
AccountNum accountNum;
switch(_choice)
case 1:
accountNum = '1101';
break;
case 2:
accountNum = '1102';
break;
return accountNum;
If you're look for an example in the standard code, you can find class "SysQueryRangeUtilDMF" in the AOT.
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 14.09.2017 13:11
daxmusings: The Overall Concept of Extensions in AX 7 Blog bot DAX Blogs 0 04.10.2016 12:11
daxmusings: Custom Query Range Functions using SysQueryRangeUtil Blog bot DAX Blogs 0 31.07.2013 18:11
vasantharivali: Dynamic Query Using Aggregative Functions and Joins Blog bot DAX Blogs 0 17.11.2012 11:12
Часовой пояс GMT +3, время: 07:29.
