Старый 26.02.2019, 05:13   #1
25,644 / 848 (80) +++++++
TempDB table populated in CIL
Источник: http://alexvoy.blogspot.com/2019/02/...ed-in-cil.html
We have multiple options to provide additional information to records in grids. Some of them, like display methods, are easy to implement. Some of them, like a temporary table, are not.
Let's consider a scenario when our lovely user wants to see reservation info directly in the transaction grid as filterable columns.
Evidently, we cannot use display methods because they cannot be filterable. Given the way this info calculated behind the curtain, there is no way to create a view to join InventTrans on InventTransItem form. So, the last feasible option is to create a temporary table and join it to the main form data source.
In order to populate this TempDB table (it is not enough to create an InMemory one) as much fast as possible, we have to run the logic in CIL.
The following shows how to work with such tables by passing their physical names.
First, create a TempDB table.
Then add it to the form data source so that it would be outer joined to InventTrans table
and place its Init() method, which links the local buffer with a populated TempDB on the SQL server side.
We also need to init its populating engine and calculate its data at least once when the form opens and maybe later via Refresh button for all or one particular item.
final class FormRun extends ObjectRun
wblInventSumFormEngine wblInventSumFormEngine;
void init()
super();
element.wblInitParameters();
private void wblInitParameters()
wblInventSumFormEngine = new wblInventSumFormEngine(element);
//wblTmpInventSum_DS.Init
public void init()
wblTmpInventSum wblTmpInventSumLoc;
wblTmpInventSumLoc.doInsert();
delete_from wblTmpInventSumLoc;
super();
wblTmpInventSum.linkPhysicalTableInstance(wblTmpInventSumLoc);
public void run()
super();
element.wblRecalcData();
public void wblRecalcData(boolean _forCurrentItemOnly = false)
wblInvenTransByItemDimView wblInvenTransByItemDimView;
if(_forCurrentItemOnly)
wblInventSumFormEngine.parmItemIdCalcFor(InventTrans.ItemId);
wblInventSumFormEngine.run();
else
wblInventSumFormEngine.parmItemIdCalcFor('');
// todo: uncomment if needed to measure the execution time
//wblInventSumFormEngine.parmShowCalcInfo(true);
startLengthyOperation();
endLengthyOperation();
Now let's take a look at the populating class. It has parameters for showing elapsed time and run for a particular item id only.
/// Populating TempDB tables in CIL
/// Passing physical table names between CIL and form
public class wblInventSumFormEngine
// add more data sources to support multiple TempDB tables populating
FormDataSource fdsTmpInventSum;
wblTmpInventSum wblTmpInventSum;
ItemId itemIdCalcFor;
boolean showCalcInfo;
/// Gets TempDB tables physical names
/// Container with names
/// Creates buffers if not exist yet
private container getTempTablesNames()
if(!wblTmpInventSum.getPhysicalTableName())
select firstOnly wblTmpInventSum;
return [wblTmpInventSum.getPhysicalTableName()];
/// Creates new populating engine for a given form
/// Caller form
/// Looks for a particular data sources to link TempDB tables
public void new(FormRun _formRun = null)
Object formObject = _formRun;
if (_formRun)
fdsTmpInventSum = _formRun.dataSource(tableId2Name(tableNum(wblTmpInventSum)));
/// To calculate TempDB table for a particular item only
/// Item id to calculate data
/// Item id
/// If empty, then calculate for all items
public ItemId parmItemIdCalcFor(ItemId _parm = itemIdCalcFor)
itemIdCalcFor = _parm;
return itemIdCalcFor;
/// Show consumed time to populate TempDB tables
/// Shows if True
public boolean parmShowCalcInfo(boolean _parm = showCalcInfo)
showCalcInfo = _parm;
return showCalcInfo;
public void run()
str wblTmpInventSumTempDBTableName;
// add here more tempDB tables if needed
[wblTmpInventSumTempDBTableName] = this.getTempTablesNames();
[wblTmpInventSumTempDBTableName] = wblInventSumFormEngine::calc([itemIdCalcFor, wblTmpInventSumTempDBTableName, showCalcInfo]);
// push calculated data back to the form data source
if(fdsTmpInventSum)
// this assignment works only on the client tier outside of the populating method
fdsTmpInventSum.cursor().linkPhysicalTableInstance(wblTmpInventSum);
fdsTmpInventSum.research();
/// Launcher for CIL
/// Container with parameters and all TempDB tables physical names to populate
/// Container with all populated TempDB tables physical names
private static server container calc(container _cont)
container cont;
XppILExecutePermission xppILExecutePermission;
FromTime startTime = timeNow();
ItemId itemIdCalcFor = conPeek(_cont, 1);
boolean showCalcInfo = conPeek(_cont, 3);
xppILExecutePermission = new XppILExecutePermission();
xppILExecutePermission.assert();
cont = runClassMethodIL(
classStr(wblInventSumFormEngine),
staticMethodStr(wblInventSumFormEngine, calcIL),
_cont
CodeAccessPermission::revertAssert();
if(showCalcInfo)
info(strFmt("Refreshed for %1 in %2", itemIdCalcFor ? itemIdCalcFor : "all items", timeConsumed(startTime, timeNow())));
return cont;
/// Implements the calculating logic and populating TempDB tables
private static server container calcIL(container _con)
WHSInventReserve whsInventReserve;
ItemId itemIdCalcFor = conPeek(_con, 1);
str wblTmpInventSumTempDBTableName = conPeek(_con, 2);
// Link to an exiting table
wblTmpInventSum.useExistingTempDBTable(wblTmpInventSumTempDBTableName);
// empty existing data
wblInventSumFormEngine::cleanTmpInventSum(wblTmpInventSum, itemIdCalcFor);
/***** Implements the calculating logic here *****/
while select whsInventReserve
join RecId from wblInvenTransByItemDimView
where
(!itemIdCalcFor || whsInventReserve.ItemId == itemIdCalcFor) &&
wblInvenTransByItemDimView.ItemId == whsInventReserve.ItemId &&
wblInvenTransByItemDimView.InventDimId == whsInventReserve.InventDimId
wblTmpInventSum.clear();
wblTmpInventSum.Itemid = whsInventReserve.itemId;
wblTmpInventSum.InventDimId = whsInventReserve.InventDimId;
wblTmpInventSum.AvailOrdered = whsInventReserve.AvailOrdered;
wblTmpInventSum.AvailPhysical = min(whsInventReserve.displayPhysAvailUpHierarchy(), whsInventReserve.AvailPhysical);
// here you can add any other method calls to get more info about reservation
wblTmpInventSum.AvailReservDelta = wblTmpInventSum.AvailPhysical - wblTmpInventSum.AvailOrdered;
wblTmpInventSum.insert();
// send tables physical names back to the form
/// Empties the whole table or for given item id only
/// TempDB table buffer to empty
/// Item id
static private void cleanTmpInventSum(wblTmpInventSum _wblTmpInventSum, ItemId _itemIdCalcFor = '')
delete_from _wblTmpInventSum
where
(!_itemIdCalcFor || _wblTmpInventSum.ItemId == _itemIdCalcFor);
As you can see the tricky point is to provide tables physical names to CIL and back in calc() and calcIL() methods.
Now you get it.
Do not forget to build CIL and check it in your Development user options.
cil
TempDB table on a form with multiple updates Blog bot DAX Blogs 0 10.03.2018 00:14
saurav-nav: NAV 2018 - Lots of New Objects! Blog bot NAV: Blogs 0 04.12.2017 10:11
wiki.dynamicsbook: Changes Made in Navision Attain 3.01B Blog bot Dynamics CRM: Blogs 0 21.08.2008 20:43
wiki.dynamicsbook: Changes Made in Navision Attain 301 Blog bot Dynamics CRM: Blogs 0 19.08.2008 13:44
Часовой пояс GMT +3, время: 16:44.
