Старый 09.09.2019, 14:12   #1
25,644 / 848 (80) +++++++
crmtipoftheday: Tip #1304: Why can’t I export my failures?
Источник: https://crmtipoftheday.com/1304/why-...t-my-failures/
You use the import utility in Dynamics, and sometimes you get the option to export your failed row and sometimes you don’t. What gives?
The answer is it depends on your import file type. If you import from XML or from CSV, you will get the Export error rows option.
If you import from xlsx, the export error row option will not be there.
crmtipoftheday: Tip #1294: Export solution before running solution checker Blog bot Dynamics CRM: Blogs 0 13.08.2019 18:12
crmtipoftheday: Tip #1204: Export marketing lists with more information Blog bot Dynamics CRM: Blogs 0 05.12.2018 15:11
alexef: Sample Extension v2.0 — Dynamics NAV / AL extension / SaaS — ALF Export Setup Tabs to Excel Blog bot NAV: Blogs 3 05.10.2018 23:13
crmtipoftheday: Tip #1095: Add percentage labels to pie charts Blog bot Dynamics CRM: Blogs 0 02.04.2018 04:16
crmtipoftheday: Tip #1060: Quickly create vector/SVG images for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 24.01.2018 22:11
Часовой пояс GMT +3, время: 12:47.
