Старый 23.04.2016, 23:20   #1
mnt_dx is offline
mnt_dx
1,748 / 158 (9) ++++++
Перестал работать enterprise portal
Виртуалка DAX 2012 r3, портал отлично работал, ничто не предвещало беды, но вдруг открываю портал (адрес http://intranet.contoso.com/sites/Dy...WDPK=initial/0
и вижу ошибку(!)
Error
Message: An unhandled error has occurred. To view details about this error, enable debugging in the web.config file or view the Windows event logs.
Пошел в евент вьюер, а там так:
Cannot create file mapping.
System
at System.Diagnostics.SharedPerformanceCounter.FileMapping.Initialize(String fileMappingName, Int32 fileMappingSize, Int32 initialOffset)
at System.Diagnostics.SharedPerformanceCounter.GetCategoryData()
at System.Diagnostics.SharedPerformanceCounter..ctor(String catName, String counterName, String instanceName, PerformanceCounterInstanceLifetime lifetime)
at System.Diagnostics.PerformanceCounter.InitializeImpl()
at System.Diagnostics.PerformanceCounter..ctor(String categoryName, String counterName, String instanceName, Boolean readOnly)
at Microsoft.Dynamics.AX.ManagedInterop.RuntimeContext.InitializePerformanceCounters(String categoryName)
at Microsoft.Dynamics.Framework.BusinessConnector.PerformanceCounters..cctor()
Microsoft Dynamics AX could not locate the Web server. Verify that Enterprise Portal is installed on the Web server. If Enterprise Portal is installed, verify that the server is available on the network.
Пошел в гуголь, там посоветовали сделать Deploy портала в DAX. Стал деплоить, но и тут ошибка:
Рецепт отсюда не помог.
В эвент вьюере пачка ошибок после деплоя. Последняя такая:
Setup encountered an error during deployment of the Role Center and Enterprise Portal framework.
\Web
Microsoft.Dynamics.Framework.BusinessConnector.Session.Exceptions.FatalSessionException: Dynamics Object Adapter Call failed. ---> System.Threading.ThreadAbortException: Thread was being aborted.
at cqlClass.callEx(cqlClass* , Char* , interpret* )
at AxCore.AxRuntime.Call(AxRuntime* , IAxObject* axObject, String methodName, Type returnType, Object& result, Object[] paramList)
at Microsoft.Dynamics.AX.ManagedInterop.Object.CallWithReturnType(String methodName, Type returnType, Object[] paramList)
at Microsoft.Dynamics.AX.ManagedInterop.Object.Call(String methodName, Object param1, Object param2, Object param3)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsObjectAdapter.Call(String methodName, Object param1, Object param2, Object param3)
--- End of inner exception stack trace ---
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsSession.HandleException(String message, Exception exception, HandleExceptionCallback callback)
at Microsoft.Dynamics.Framework.BusinessConnector.Proxy.SysEPDeployment.deployWebComponent(String treeNodePath, String virtualServerUrl, String siteUrl)
at Microsoft.Dynamics.Framework.Deployment.Portal.EPDeployment.DeployWebComponent(String treeNodePath, String virtualServerUrl, String webSiteUrl, Boolean resetIIS, Nullable`1 modifiedAfter)
Что делать, как починить?
Старый 26.04.2016, 00:56   #2
griefon is offline
griefon
131 / 52 (2) ++++
А iisreset на сервере с IIS сделали? (для этого надо запустить командную строку в режиме администратора и потом выполнить эту команду)
Старый 26.04.2016, 16:59   #3
mnt_dx is offline
mnt_dx
Сообщение от griefon Посмотреть сообщение
Да, из командной строки перезапускал - результата не дало.
Помог рестарт виртуалки, но причину грехопадения портала я так и не понял.
Интересно, что в IIS я не вижу отдельного сайта портала:
Название: Список сайтов.PNG
Старый 27.04.2016, 02:13   #4
griefon is offline
griefon
131 / 52 (2) ++++
Пытаться понять, почему портал криво работает - малоэффективное занятие. Но портал должен быть в списке сайтов как одно из приложений SharePoint.
Старый 27.11.2019, 10:34   #5
Logger is offline
Logger
3,996 / 3293 (117) ++++++++++
Записей в блоге: 2
Сообщение от mnt_dx Посмотреть сообщение
Здравствуйте. Столкнулся с той же проблемой.
Как вы ее побеждали ?
Старый 27.11.2019, 18:50   #6
Logger is offline
Logger
Записей в блоге: 2
https://community.dynamics.com/ax/f/...34=2#responses
Deploying Managed Web Content Error
Unanswered
Hi Matt,
I know it is a long time ago, but it might be still relevant to you or to others visiting this topic.
I ran into the same issue as you did just yet and then I recalled an another issue I had when I installed Enterprise Portal.
In the end this was solved by renaming the
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\15.0
registry key into
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\15.0_xx
Hope this might help you or others.
Я так понимаю что у топикастера по ссылке стоял 2010-й Sharepoint (14-я версия как и в моем случае) а акапта по умолчанию ищет сперва 15-ю версию и если в реестре есть ветка HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\Web Server Extensions\15.0
то дальше аксапта пытается работать только с ней, н находит нужных вещей и падает в ошибку.
В общем, в моем случае деплой портала починился.
deploy, issue, sharepoint, sharepoint 2010
emeadaxsupport: How to install AX 2012 Enterprise Portal in a multi-server web farm Blog bot DAX Blogs 0 09.11.2015 13:11
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Enterprise Portal Screencasts at Channel9.msdn.com Blog bot DAX Blogs 6 01.07.2008 19:38
jinx: Microsoft Dynamics AX 2009 Enterprise Portal Entwicklung Samples Blog bot DAX auf Deutsch 0 27.06.2008 04:06
Часовой пояс GMT +3, время: 16:29.
