Старый 24.02.2020, 20:13   #1
a33ik: Available physical on exact dimensions
Источник: http://daxonline.org/1679-available-...imensions.html
If case of following conditions
  • Item is enabled for advanced warehousing
    WHSInventEnabled::exist(ItemId);
  • some warehouses have negative stock
You will see that Available physical figure is different from what you most probably want to get:
In this case Available physical will display total value across all warehouses or any other dimensions you stated as a criteria.
Available physical on exact dimensions will display correct value considering specified dimensions.
Here is how to get correct values from X++:
static void VKAvailablePhysical(Args _args){ Qty qty; InventDim inventDim; InventDimParm inventDimParm; InventOnHandQty inventOnHandQty; ItemId itemId = '11011'; InventAvailabilityByUnit inventAvailabilityByUnit; WhsInventReserveQty whsInventReserveQty; InventIAvailability inventIAvailability; inventDim.clear(); inventDim.InventSiteId = 'SiteId'; inventDim.InventLocationId = 'Warehouse'; inventDim = inventDim::findOrCreate(inventDim); // Available physical inventDimParm.initFromInventDim(inventDim); inventOnHandQty = InventOnHandQty::newItemDim(itemId, inventDim, inventDimParm); qty = inventOnHandQty.availPhysical(); // Available physical on exact dimensions inventAvailabilityByUnit = inventAvailabilityProvider::findByItemIdDim(itemId, inventDim); inventIAvailability = inventAvailabilityByUnit.parmInventAvailability(); if (inventIAvailability is WhsInventReserveQty) { whsInventReserveQty = inventIAvailability as WhsInventReserveQty; qty = whsInventReserveQty.availPhysicalLevel(); }}
a33ik: AX2012: X++ Code to verify active stock dimensions on an item Blog bot DAX Blogs 0 03.10.2018 15:11
a33ik: Transfer order receive item with different than default storage dimensions Blog bot DAX Blogs 0 03.05.2018 18:12
stoneridgesoftware: How to Set up Required Dimensions in Dynamics 365 Business Edition Blog bot DAX Blogs 0 03.08.2017 00:13
dynamicsaxtraining: Get “available physical” values for specific item+dimensions per batch Blog bot DAX Blogs 0 17.10.2011 20:11
Часовой пояс GMT +3, время: 22:18.
