Старый 27.08.2021, 20:15   #1
25,644 / 848 (80) +++++++
d365technext: Database sync failed during Dimension Activation
Источник: http://d365technext.blogspot.com/202...dimension.html
If you are facing the Database sync failure and below error while activating the Financial dimension in maintenance mode.
Please perform the following steps to resolve this issue
You need to fix your data. Go to the Visual studio find inventdim table then check what fields are in "DimIdx" index.
Then Open the SQL and execute the below query to confirm either you have duplicate Invent Dim or nor
select InventDimId from INVENTDIM
group by InventDimId
having count(*)>1
When records will be identified you need to make a decision on what to do with them. fix data or delete.
Error Message
Managed Data Sync Entity Worker encountered an exception, but is continuing because ContinueOnError is true. View Name and ID: Managed Data Sync Entity Worker encountered an exception, but is continuing because ContinueOnError is true. View Name and ID: 'DimensionCombinationEntity(5502)' Exception: System.InvalidOperationException: Database execution failed: Incorrect syntax near ')'.
CREATE VIEW [DBO].[DIMENSIONCOMBINATIONENTITY] AS SELECT T1.RECID AS RECORDID, T1.MAINACCOUNTVALUE AS MAINACCOUNT, T1.MODIFIEDDATETIME AS MODIFIEDDATETIME, T1.MODIFIEDBY AS MODIFIEDBY, T1.CREATEDDATETIME AS CREATEDDATETIME, T1.CREATEDBY AS CREATEDBY, T1.RECVERSION AS RECVERSION, T1.PARTITION AS PARTITION, T1.RECID AS RECID, T2.NAME AS ACCOUNTSTRUCTURE, T2.RECVERSION AS RECVERSION#2, T2.PARTITION AS PARTITION#2, T2.RECID AS RECID#2, (CAST ((
SELECT (
REPLACE(
REPLACE(
REPLACE(
CASE WHEN
T1.LEDGERDIMENSIONTYPE != 1
THEN
(SELECT CASE WHEN
NonNullDisplayValue IS NOT NULL
THEN NonNullDisplayValue
ELSE 'No active format for data entities has been set up.
Set up an active format for each dimension format type.'
END
FROM
(SELECT (
-- Remove initial delimiter
STUFF(
(SELECT
-- Prepend with delimiter and escape internal delimiters
DIMENSIONSEGMENTDELIMITER + COALESCE(
REPLACE(REPLACE(DIMLIST.COLUMNVALUE, '\', '\\'),
DIMENSIONSEGMENTDELIMITER,
DIMENSIONSEGMENTDELIMITERESCAPED),
FROM
-- Get the dimension hierarchy
(SELECT TOP(1) DH.RECID
FROM DIMENSIONHIERARCHY DH
JOIN DIMENSIONHIERARCHYINTEGRATION DHI
ON DHI.DIMENSIONHIERARCHY = DH.RECID
AND DHI.ISDEFAULT = 1
AND DHI.PARTITION = T1.PARTITION
WHERE
DH.PARTITION = T1.PARTITION
AND DH.STRUCTURETYPE =
CASE T1.LEDGERDIMENSIONTYPE
WHEN 0 THEN 18
WHEN 2 THEN 19
WHEN 4 THEN 20
END
) AS DH
JOIN DIMENSIONHIERARCHYLEVEL DHL
ON DHL.DIMENSIONHIERARCHY = DH.RECID AND DHL.PARTITION = T1.PARTITION
JOIN DIMENSIONATTRIBUTE DA
ON DA.RECID = DHL.DIMENSIONATTRIBUTE AND DA.PARTITION = T1.PARTITION
LEFT JOIN
(SELECT DIMENSIONATTRIBUTE, COLUMNVALUE
FROM
(SELECT * FROM DIMENSIONATTRIBUTEVALUECOMBINATION DAVC
WHERE DAVC.PARTITION = T1.PARTITION AND DAVC.RECID = T1.RECID) P
UNPIVOT
(COLUMNVALUE for DIMENSIONATTRIBUTE IN (MAINACCOUNTVALUE)) AS DIMENSIONVALUECOLUMNNAME
) AS DIMLIST
ON
DIMLIST.DIMENSIONATTRIBUTE = REPLACE(DA.DIMENSIONVALUECOLUMNNAME COLLATE Database_Default, '.', '$')
ORDER BY DHL.DIMENSIONHIERARCHY, DHL.LEVEL_
FOR XML PATH('')
1, LEN(DIMENSIONSEGMENTDELIMITER), '')
) AS NonNullDisplayValue)
AS DisplayValueFormat)
ELSE
-- Default or dynamic accounts
(SELECT REPLACE(REPLACE(T1.DISPLAYVALUE, '\', '\\'),
DIMENSIONSEGMENTDELIMITERESCAPED))
END
FROM
(SELECT TOP(1)
--Determine the segment delimiter
CASE DIMENSIONSEGMENTDELIMITER
WHEN 0 THEN '-'
WHEN 1 THEN '.'
WHEN 2 THEN '_'
WHEN 3 THEN '|'
WHEN 7 THEN '||'
WHEN 8 THEN '~'
WHEN 4 THEN '--'
WHEN 5 THEN '..'
WHEN 6 THEN '__'
WHEN 9 THEN '~~'
END AS DIMENSIONSEGMENTDELIMITER,
--Determine the account delimiter escaped
WHEN 0 THEN '\-'
WHEN 1 THEN '\.'
WHEN 2 THEN '\_'
WHEN 3 THEN '\|'
WHEN 7 THEN '\|\|'
WHEN 8 THEN '\~'
WHEN 4 THEN '\-\-'
WHEN 5 THEN '\.\.'
WHEN 6 THEN '\_\_'
WHEN 9 THEN '\~\~'
END AS DIMENSIONSEGMENTDELIMITERESCAPED
FROM DIMENSIONPARAMETERS
WHERE DIMENSIONPARAMETERS.PARTITION = T1.PARTITION
) AS DIMENSIONPARAMETERS
) AS NVARCHAR(500))) AS DISPLAYVALUE, (CAST ((T1.DISPLAYVALUE) AS NVARCHAR(30))) AS ACCOUNTVALUE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS BANKACCOUNTID, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS CLIENTORGANIZATIONUNIT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS DELIVERYCHANNEL, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS FINALCLIENT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS INTERCOMPANY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSKILLSET, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBINDUSTRY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBSERVICELINE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PL_PODATEK, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PROGRAMWBS, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS VENDORLEGALENTITY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALCOSTCENTER FROM DIMENSIONATTRIBUTEVALUECOMBINATION T1 LEFT OUTER JOIN DIMENSIONHIERARCHY T2 ON(( T1.ACCOUNTSTRUCTURE = T2.RECID) AND ( T1.PARTITION = T2.PARTITION)) ---> System.Data.SqlClient.SqlException: ) AS NVARCHAR(500))) AS DISPLAYVALUE, (CAST ((T1.DISPLAYVALUE) AS NVARCHAR(30))) AS ACCOUNTVALUE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS BANKACCOUNTID, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS CLIENTORGANIZATIONUNIT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS DELIVERYCHANNEL, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS FINALCLIENT, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS INTERCOMPANY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSKILLSET, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBINDUSTRY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALSUBSERVICELINE, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PL_PODATEK, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS PROGRAMWBS, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS VENDORLEGALENTITY, (CAST ((SELECT TOP 1 T1. ) AS NVARCHAR(30))) AS LOCALCOSTCENTER FROM DIMENSIONATTRIBUTEVALUECOMBINATION T1 LEFT OUTER JOIN DIMENSIONHIERARCHY T2 ON(( T1.ACCOUNTSTRUCTURE = T2.RECID) AND ( T1.PARTITION = T2.PARTITION)) ---> System.Data.SqlClient.SqlException: Incorrect syntax near ')'.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlCommand.RunExecuteNonQueryTds(String methodName, Boolean async, Int32 timeout, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.InternalExecuteNonQuery(TaskCompletionSource`1 completion, String methodName, Boolean sendToPipe, Int32 timeout, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.ExecuteNonQuery()
at Microsoft.Practices.EnterpriseLibrary.TransientFaultHandling.SqlCommandExtensions.c__DisplayClass1.b__0()
at Microsoft.Practices.EnterpriseLibrary.TransientFaultHandling.RetryPolicy.ExecuteAction[TResult](Func`1 func)
at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.b__30_0(SqlCommand c)
at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.ExecuteSql[T](SqlCommand cmd, Func`2 sqlFunc)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at Microsoft.Dynamics.AX.Data.Sql.SqlDataAccessManager.HandleException(ExceptionDispatchInfo edi, SqlExecutionInfo execInfo)
at Microsoft.Dynamics.AX.Data.Management.DBExecute.ExecuteDDLWithNewTransaction(IEnumerable`1 commandTextInBatch)
--- End of inner exception stack trace ---
at Microsoft.Dynamics.AX.Data.Management.DBExecute.ThrowOnSqlExecuteException(SqlException e, String commandText)
at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.SyncAllAction[T](ViewSyncGraphNode viewToSync, Dictionary`2 oldViewDefinitions, StringCollection dataEntityViewList, StringCollection compositeEntityViewList, IProducerConsumerCollection`1 modifiedViewDependencies)
at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.DoSyncAll[T](IEnumerable`1 sortedViewList, Dictionary`2 oldViewDefinitions, IProducerConsumerCollection`1 modifiedViewDependencies)
AOS database sync failed. Microsoft.Dynamics.AX.Framework.Database.TableSyncException: AOS database sync failed. Microsoft.Dynamics.AX.Framework.Database.TableSyncException: Full sync did not complete successfully. Error: AggregateException:One or more errors occurred.
at Microsoft.Dynamics.AX.Data.Management.ManagedSyncWorkerManager.SyncAll()
at Microsoft.Dynamics.AX.Data.Management.ManagedSync.b__21_0()
at Microsoft.Dynamics.AX.Data.Management.ManagedSync.EnsureMetadataProviderCacheCleared(Action action)
at Microsoft.Dynamics.AX.Data.Management.ManagedSync.SyncAll()
at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.RunFullManagedSync(SyncOptions options, String sqlConnectionString, IMetadataProvider metadataProvider)
at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.c__DisplayClass20_0.b__0()
at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.ExecuteWithinAOS(SyncOptions syncOptions, String sqlConnectionString, IMetadataProvider metadataProvider, Func`1 func, Action`1 errorHandler)
Inner exceptions:
Database execution failed: Database execution failed: Incorrect syntax near ')'.
at Microsoft.Dynamics.AX.Data.Management.DataEntity.ManagedSyncDataEntityWorker.DoSyncAll[T](IEnumerable`1 sortedViewList, Dictionary`2 oldViewDefinitions, IProducerConsumerCollection`1 modifiedViewDependencies).
at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.c.b__20_1(Tuple`2 result)
at Microsoft.Dynamics.AX.Framework.Database.Tools.LegacyCodepath.RunFullTableSync(SyncOptions syncOptions, String sqlConnectionString, IMetadataProvider metadataProvider)
at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.FullTableViewSync()
at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.FullSync()
at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.RunSync()
at Microsoft.Dynamics.AX.Framework.Database.Tools.SyncEngine.Run(String metadataDirectory, String sqlConnectionString, SyncOptions options)
Process: syncengine.exe exited with code -1.
emeadaxsupport: AX2012 Retail: MS Sync Service fails to synchronize transactions from offline database Blog bot DAX Blogs 0 15.08.2012 09:11
NAV Team: Filtering on Dimension Values Blog bot Dynamics CRM: Blogs 0 12.06.2012 18:02
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
NAV Team: CREATE DATABASE failed when installing Cronus Sample Database Blog bot Dynamics CRM: Blogs 0 27.10.2009 15:29
Часовой пояс GMT +3, время: 00:38.
