Старый 09.09.2021, 22:13   #1
d365technext: What is AOT in AX & D365FO
Источник: https://d365technext.blogspot.com/2021/09/VSAOT.html
Define AOT in AX & D365FO
The Application Object Tree (AOT) is a tree view of all the application objects within Microsoft Dynamics AX and D365FO. The AOT contains everything you need to customize the look and functionality of a Microsoft Dynamics AX application.
In the D365FO, You can find the AOT objects in Application Explorer.
d365technext: What are AOS in AX & D365FO Blog bot DAX Blogs 0 09.09.2021 22:13
d365technext: Compare Records D365FO & AX 2012 Blog bot DAX Blogs 0 16.11.2018 16:11
d365technext: Override Lookup AX7 & D365FO Blog bot DAX Blogs 0 02.08.2018 18:12
d365technext: Card Pattern in Grid D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 11:11
Часовой пояс GMT +3, время: 15:11.
