Старый 03.11.2021, 22:20   #1
thwidmer: Functions to use in Queries, Filters (2021
Источник: https://thwidmer.wordpress.com/2021/...-filters-2021/
Update to my old Blog post Functions to use in Queries, Filters
There are many new functions that can be used in Queries. In the code they are marked with [QueryRangeFunction()] or [QueryRangeFunctionAttribute()]
see https://calafell.me/the-utility-of-q...in-management/ for a comprehensive list and a script to compile a new list your current list.
Use by providing the full class and method e.g. UserExternalQueryRangeFunction::currentUserExternalParty()
Current list as of 10.0.22
  • str SysQueryRangeUtilDMF::greaterThanLastActivityStartedDateTime()
  • str SysQueryRangeUtilDMF::greaterThanLastActivityCompletedDateTime()
  • str SysQueryRangeUtilDMF::greaterThanLastSuccessfulExecutionDateTime()
  • str SysQueryRangeUtilDMF::greaterThanLastExecutionDateTime()
  • str SysQueryRangeUtilDMF::notExportableUser()
  • RecId UserExternalQueryRangeFunction::currentUserExternalParty()
  • date SysQueryRangeUtil::currentDate()
  • str SysQueryRangeUtil::currentLanguageId()
  • str SysQueryRangeUtil::currentSessionDate()
  • str SysQueryRangeUtil::currentSessionDateTime()
  • str SysQueryRangeUtil::currentUserId()
  • str SysQueryRangeUtil::anyUserIdNotCurrent()
  • str SysQueryRangeUtil::currentUserLanguage()
  • str SysQueryRangeUtil::dateRange(date _startDate, date _endDate)
  • str SysQueryRangeUtil::day(int relativeDays = 0)
  • str SysQueryRangeUtil::dayRange(int relativeDaysFrom = 0, int relativeDaysTo = 0)
  • str SysQueryRangeUtil::greaterThanDate(int relativeDays = 0)
  • str SysQueryRangeUtil::greaterThanUtcDate(int relativeDays = 0)
  • str SysQueryRangeUtil::greaterThanUtcNow()
  • str SysQueryRangeUtil::lessThanDate(int relativeDays = 0)
  • str SysQueryRangeUtil::lessThanUtcDate(int relativeDays = 0)
  • str SysQueryRangeUtil::lessThanUtcNow()
  • str SysQueryRangeUtil::monthRange(int relativeMonthsFrom = 0, int relativeMonthsTo = 0)
  • str SysQueryRangeUtil::yearRange(int relativeYearsFrom = 0, int relativeYearsTo = 0)
  • str SysQueryRangeUtil::value(anytype a)
  • str SysQueryRangeUtil::valueEmptyString()
  • str SysQueryRangeUtil::valueUnlimited()
  • SelectableDataArea SysQueryRangeUtil::currentCompany()
  • utcdatetime SysQueryRangeUtil::getCurrentSessionDateTime()
  • str SysQueryRangeUtil::literalFilterValue(str nonLiteralFilterValue)
  • utcdatetime SysQueryRangeUtil::dateTimeMinValue()
  • str AgreementClassificationEntityHelper::salesAgreementClassificationRangeConfiguration()
  • str AgreementClassificationEntityHelper::purchAgreementClassificationRangeConfiguration()
  • str AgreementClassificationEntityHelper::agreementClassificationRangeConfiguration()
  • str AgreementConfirmationLineEntityHelper::assignLinesToHeadersByDateEffectiveness_ SalesAgreementConfirmation()
  • str AgreementConfirmationLineEntityHelper::assignLinesToHeadersByDateEffectiveness_ PurchaseAgreementConfirmation()
  • RefRecId CompanyInfoHelper::currentLegalEntity()
  • str CustCustomerExternalCodeClassEntityHelper::queryRangeExpressionCustTableTableId()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeConfiguration()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeSize()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeColor()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeStyle()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeVersion()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeSite()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeWarehouse()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeLocation()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeStatus()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeLicensePlate()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeBatch()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeSerial()
  • str EcoResDimensionGroupEntityHelper::productDimensionRangeInventoryOwner()
  • str EcoResDimensionGroupEntityHelper_RU::productDimensionRangeInventoryProfile()
  • str EcoResDimensionGroupEntityHelper_RU::productDimensionRangeGTD()
  • str EcoResProductDimensionQueryRangeHelper::productDimensionRangeColor(DataSourceName _dataSource1Name, DataSourceName _d
  • ataSource2Name, boolean _allowEmptyDimension = true)
  • str EcoResProductDimensionQueryRangeHelper::productDimensionRangeSize(DataSourceName _dataSource1Name, DataSourceName _da
  • taSource2Name, boolean _allowEmptyDimension = true)
  • str EcoResProductDimensionQueryRangeHelper::productDimensionRangeStyle(DataSourceName _dataSource1Name, DataSourceName _d
  • str EcoResProductDimensionQueryRangeHelper::productDimensionRangeConfiguration(DataSourceName _dataSource1Name, DataSourc
  • eName _dataSource2Name, boolean _allowEmptyDimension = true)
  • str EcoResProductDimensionQueryRangeHelper::productDimensionRangeVersion(DataSourceName _dataSource1Name, DataSourceName
  • _dataSource2Name, boolean _allowEmptyDimension = true)
  • str EcoResProductEntityHelper::queryRangeExpressionNotVariant()
  • str EcoResProductMasterDimensionEntityHelper::productDimensionColorTableId()
  • str EcoResProductMasterDimensionEntityHelper::productDimensionConfigurationTableId()
  • str EcoResProductMasterDimensionEntityHelper::productDimensionSizeTableId()
  • str EcoResProductMasterDimensionEntityHelper::productDimensionStyleTableId()
  • str EcoResProductMasterDimensionEntityHelper::productDimensionVersionTableId()
  • str EcoResReleasedProductExternalCodeClassEntityHelper::queryRangeExpressionInventTableTableId()
  • str EcoResReleasedProductVariantExternalCodeClassEntityHelper::queryRangeExpressionInventDimCombinationTableId()
  • str FormLetterSortingParametersEntityHelper::procurementTableRangeValues()
  • str FormLetterSortingParametersEntityHelper::salesTableRangeValues()
  • str IntrastatEntityHelper::intrastatCommodityCodeEntityRangeDataAreaId()
  • str InventInventoryDimensionsParametersEntityHelper::tableNumInventDim()
  • str InventInventoryDimensionsParametersEntityHelper::includedFieldIds()
  • str InventLedgerPostingDefinitionEntityHelper::inventAccountTypeInventFilter()
  • str InventLedgerPostingDefinitionEntityHelper::inventAccountTypeProdFilter()
  • str InventLedgerPostingDefinitionEntityHelper::inventAccountTypePurchFilter()
  • str InventLedgerPostingDefinitionEntityHelper::inventAccountTypeSalesFilter()
  • str InventLedgerPostingDefinitionEntityHelper::inventAccountTypeStdCostVarianceFilter()
  • FieldId InventSysQueryRangeUtil::inventBatchIdFieldNum()
  • FieldId InventSysQueryRangeUtil::wMSLocationIdFieldNum()
  • str PmfSysQueryRun::pmfInventTableIsBOMFormula()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenScheduledAndStartedUp()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenScheduledAndReportedFinished()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenCostEstimatedAndStartedUp()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenStartedUpAndReportedFinished()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenCostEstimatedAndReportedFinished()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenCreatedAndStartedUp()
  • str ProdStatusSysQueryRangeUtil::prodStatusBetweenCreatedAndReportedFinished()
  • str PurchaseRequisitionEntityHelper::getPurchaseRequsitionHeaders()
  • str PurchPurchaseOrderUpdateLinesParametersEntityHelper::tableNumPurchTable()
  • str PurchPurchaseOrderUpdateLinesParametersEntityHelper::includedFieldIds()
  • str PurchPurchasingPolicyEntityHelper::purchasingPolicyType()
  • str PurchPurchasingPolicyEntityHelper::purchReqLineFilterQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequisitionProcurementCatalogPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequisitionConsumptionCategoryAccessPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseCategoryPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequistionControlRFQPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequistionConsumptionControlPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequistionPurposePolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequistionReplenishmentCategoryAccessPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseRequistionReplenishmentControlPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchaseOrderCreationAndDemandConsolidationPolicyRuleQueryRangeValue()
  • str PurchPurchasingPolicyEntityHelper::purchReapprovalPolicyRuleQueryRangeValue()
  • str ReqDemPlanHistoricalExternalDemandEntityHelper::queryRangeVersionForecastedExternally()
  • str ReqDemPlanHistoricalExternalDemandEntityHelper::queryRangeDataSourceOriginForecastedExternally()
  • str ReqRoutePlannedOrderRouteOperationEntityHelper::wrkCtrDateFromEffectiveness()
  • str ReqRoutePlannedOrderRouteOperationEntityHelper::wrkCtrDateToEffectiveness()
  • str RetailPeriodicDiscountQueriesHelper::getDiscountOfferTypes()
  • str RetailPeriodicDiscountQueriesHelper::getPriceOfferTypes()
  • str RetailProductWarehouseInventoryQueryHelper::getReservationHierarchyFieldIds()
  • str SalesOrderUpdateLinesParametersEntityHelper::tableNumSalesTable()
  • str SalesOrderUpdateLinesParametersEntityHelper::includedFieldIds()
  • str SalesQueryRangeUtil::salesStatusCanBeInvoiced()
  • str SalesQueryRangeUtil::salesTypeCustomerDemand()
  • str SysQueryRangeUtilProject::projActiveAll(ProjActiveAll _projActiveAll)
  • str SysQueryRangeUtilProject::projLevels(ProjLevels _projLevels)
  • str SysQueryRangeUtil_Extension::validToMaxValueRange()
  • str SysQueryRangeUtil_Extension::validToMaxValueRangeDate()
  • str TaxCodeExternalCodeClassEntityHelper::queryRangeExpressionTaxTableTableId()
  • str TMSTransportationRouteScheduleEntityHelper::getRoutePlan()
  • str TrvExpenseTransHelper::currentLegalEntity()
  • str TSQueryRangeUtil::validTimesheetFrequency()
  • TableId TSTimesheetHelper::getTSTimesheetTableId()
  • str VendVendorExternalCodeClassEntityHelper::queryRangeExpressionVendTableTableId()
  • str WHSCustomerGroupProductFilterEntityHelper::getCustomerGroups()
  • str WHSCustomerProductFilterEntityHelper::getCustomers()
  • str WHSGenerallyAvailableProductFilterEntityHelper::getGenerallyAvailableProducts()
  • str WHSProductFilterGroupDetailEntityHelper::getProductFilterGroupsQueryRange()
  • str WHSQueryHelper_BR::getRefTableIdsFromWhsFiscalDocument()
  • str WHSReleaseLoadToWarehouseSysQueryRangeUtil::loadStatus()
  • str WHSSysQueryRangeUtil::workStatusOpenOrInProcess()
  • str WHSSysQueryRangeUtil::no()
  • str WHSVendorGroupProductFilterEntityHelper::getVendorGroups()
  • str WHSVendorProductFilterEntityHelper::getVendors()
  • str WMSQueryRangeUtil::shipmentsInProgress()
  • TableId FinancialReportingGeneralJournalReversals::tableName2Id(str _tableName)
  • str AssetWorkspaceQueryHelper::currentFiscalYearRange()
  • str BudgetPlanningWorkspaceQueryRangeHelper::budgetPlanningProcess()
  • str BudgetPlanningWorkspaceQueryRangeHelper::currentDate()
  • str BudgetPlanningWorkspaceQueryRangeHelper::emptyValue()
  • str BudgetTrackingWorkspaceQueryRangeHelper::overThreshold()
  • str BudgetTrackingWorkspaceQueryRangeHelper::underThreshold()
  • str BudgetTrackingWorkspaceQueryRangeHelper::budgetPlanningProcess()
  • str BudgetTrackingWorkspaceQueryRangeHelper::currentLedger()
  • str DirRelationshipTypeHelper::getUserDefinedRelationshipTypeRange(DataSourceName _dataSourceName = ”, FieldName _system
  • TypeFieldName = fieldStr(DirRelationshipTypeTable, SystemType)
  • boolean DirUtility::currentRoleHasAccessToPrivate(boolean _useCache = true)
  • DirPartyRecId DirUtility::currentParty()
  • boolean DirPartyLocation::currentRoleHasAccessToPrivate(boolean _useCache = true)
  • DirPartyRecId DirPartyTable::currentParty()
  • str DocQueryRangeUtil::isRunningInBatch()
  • str DocQueryRangeUtil::isNotRunningInBatch()
  • str DOMConfigurationManager::notUtcNull()
  • str DOMConfigurationManager::domBatchTimeGreaterThanBatchTime()
  • str DOMConfigurationManager::getDOMClassId()
  • str DOMQueryHelper::getQueryNotValueForExcludedModesOfDelivery()
  • str EngChgTools::productDimensionRangeVersion()
  • str EntAssetSysQueryRangeUtil::greaterThanUtcDateCompanyTimezone(int relativeDays = 0)
  • RecId HcmWorkerLookup::currentPerson()
  • HcmWorkerRecId HcmWorkerLookup::currentWorker()
  • boolean EssPersonIdentificationNumberRangeUtil::skipSelfServiceReadPolicy()
  • boolean EssPersonIdentificationNumberRangeUtil::skipSelfServiceInsertUpdateDeletePolicy()
  • RefRecId HcmCompanyInfoHelper::currentLegalEntity()
  • boolean HcmPersonIdentificationNumberRangeUtil::skipSelfServiceReadPolicy()
  • boolean HcmPersonIdentificationNumberRangeUtil::skipSelfServiceInsertUpdateDeletePolicy()
  • str HcmQueryRangeUtil::getAotNameHcmHumanResourceManager()
  • str HcmQueryRangeUtil::getAotNameHcmManager()
  • HcmPositionHierarchyTypeRecId HcmQueryRangeUtil::findPositionHierarchyLineType()
  • str HcmQueryRangeUtil::lessThanCompanyDate(int _relativeDays = 0)
  • str HcmQueryRangeUtil::greaterThanCompanyDate(int _relativeDays = 0)
  • str HcmQueryRangeUtil::dateTimeRangeTodayToEndOfYearInCompanyTimezone()
  • str HcmQueryRangeUtil::currentWorkerPositionRange()
  • str HcmQueryRangeUtil::greaterThanOrEqualToUtcNow()
  • str HcmQueryRangeUtil::lessThanOrEqualToUtcNow()
  • boolean HcmWorkerActionHireRangeUtil::skipSelfServiceReadPolicy()
  • boolean HcmWorkerActionHireRangeUtil::skipSelfServiceInsertUpdateDeletePolicy()
  • boolean HcmWorkerBankAccountRangeUtil::skipSelfServiceReadPolicy()
  • boolean HcmWorkerBankAccountRangeUtil::skipSelfServiceInsertUpdateDeletePolicy()
  • str MssExitingWorkerQueryRangeUtil::dateTimeRangeExiting()
  • str MssExitingWorkerQueryRangeUtil::numberOfHierarchyResultLevelRange()
  • str HcmBenefitEligibilityPolicyEntity::hcmBenefitEligibilityPolicyType()
  • str SysPolicyEntityHelper::sysPolicyRuleTypeTableId()
$rootDirectory = "C:\AOSService\PackagesLocalDirectory"cd $rootDirectoryls "*.xml" -Recurse | % { $matches = (gc $_.FullName -ReadCount 0 | Select-String '\[QueryRangeFunction(?:Attribute)?\(?\)?\]\s+?public static ([^\r\n ]+) ([^\r\n)]+)' -AllMatches).Matches if ($matches.Count -ne 0) { $file = $_.Name.Substring(0, $_.Name.Length -4) #$fullName = $_.FullName foreach ($m in $matches) { Write-Host "$($m.Groups[1]) " -NoNewline Write-Host "$($file)." -NoNewline -ForegroundColor Gray Write-Host "$($m.Groups[2]))" } }}
d365fo
crminthefield: Dynamics 365 and Power Platform Monthly Update-September 2021 Blog bot Dynamics CRM: Blogs 0 11.09.2021 09:04
crminthefield: Dynamics 365 and Power Platform Monthly Update-August 2021 Blog bot Dynamics CRM: Blogs 0 12.08.2021 06:20
crminthefield: Dynamics 365 and Power Platform Monthly Update-July 2021 Blog bot Dynamics CRM: Blogs 0 14.07.2021 02:22
thwidmer: Electronic reporting by example: Create a new Bank file definition Blog bot DAX Blogs 0 31.01.2020 19:11
Часовой пояс GMT +3, время: 19:01.
