Старый 24.11.2022, 12:12   #1
Art Of Creation: D365 F&O: Incorrect connection string. The connection string should be of format Data Source=serverName;Initial Catalog=databaseName;Integrated Security=False;User ID=PlaceholderUserId;Password=PlaceholderPassword
Источник: http://www.artofcreation.be/2022/11/...asswordplaceh/
On the Configure entity export to database page in Data management, you can create new source data formats of the type Azure SQL DB.
When you have correctly configured the connection string and click the Validate button, you can get the following error:
You can get this error even when the format is incorrect. The issue is that Dynamics cannot connect to your database server.
In my case the firewall rules were not setup correctly. To fix this:
  1. Go to the Azure portal at https://portal.azure.com/
  2. In All resrouces, go to you database server
  3. Under Security, go to Networking
  4. Enable Allow Azure services and resources to access the server
  5. Click Save
msdynamicsworld: From the Microsoft Dynamics 365 Finance & Operations Blogs: Extensible data security; Business events; Asset leasing Blog bot DAX Blogs 0 10.07.2021 07:12
Sumit Potbhare: Retail Warehousing | Wrap up | Approach to D365 for Commerce with Adv WH Mgmt Blog bot DAX Blogs 0 28.04.2021 13:12
patrickmouwen: D365 Retail APIs Part II: How to know exactly what happens inside D365 Retail Blog bot DAX Blogs 0 14.12.2019 01:17
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 16:26.
