Старый 21.12.2022, 18:11   #1
ax.docentric: Comment on Reduce the Delay When Printing via Document Routing Agent by Miha Vuk
Источник: https://ax.docentric.com/reduce-the-...#comment-10891
At high volume printing with several parallel DRA instances on one VM you can experience the conflict while writing logs. The log folder path is hardcoded and all instances write to the same log files. DRA has some error handling, but in some cases it can still crash.System.IO.IOException: The process cannot access the file 'C:\ProgramData\Microsoft\Microsoft Dynamics 365 for Operations - Document Routing\Logs\Admin_2022_11_29.log' because it is being used by another process.Disabling "Enable logging view in application" has solved (or at least mitigated) the issue.
Часовой пояс GMT +3, время: 11:08.
