Старый 29.02.2024, 10:13   #1
dynamicsaxinsight: D365FO: Get dimension display value in X++
Источник: https://dynamicsaxinsight.wordpress....ay-value-in-x/
Purpose:
Demonstrate how can we get dimension display value in X++. This could be pretty handy when we need to display dimension display value on a custom form or an SSRS report for example.
Application:
Dynamics 365 for Finance and Operations
Solution:
You can use the following code to get the dimension display value by passing in default dimension RecId and dimension name string.
Code
/// /// Gets dimension display value. Feb 16, 24 MK/// /// /// Gets dimension display value by default dimension and dimension name./// public static DimensionValue getDimensionDisplayValue(RecId _defaultDimension, Name _dimName){ DimensionAttributeValueSetStorage dimStorage; dimStorage = DimensionAttributeValueSetStorage::find(_defaultDimension); return dimStorage.getDisplayValueByDimensionAttribute(DimensionAttribute::findByName(_dimName).RecId);}
Usage
For example, if you need to get cost center dimension value from a Purchase Order header, then you can get it by passing in the default dimension RecId of PurchTable and cost center dimension string.
#define.CostCenter("CostCenter")dimCostCenter = MAK_LedgerDimensionHelper::getDimensionDisplayValue(purchTable.DefaultDimension, #CostCenter);
dynamicsaxinsight: D365FO: Get last workflow approver for purchase orders in X++ Blog bot DAX Blogs 0 25.08.2023 20:14
NAV Team: Filtering on Dimension Values Blog bot Dynamics CRM: Blogs 0 12.06.2012 18:02
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Jim Wang: Get Entity/Attribute's Display Name from CRM database Blog bot Dynamics CRM: Blogs 0 28.03.2009 01:05
Часовой пояс GMT +3, время: 16:37.
