Старый 05.02.2009, 07:08   #1
25,643 / 848 (80) +++++++
Solutions Monkey: Deploying Ax 2009 SP1 EP
Источник: http://blogs.msdn.com/solutions/arch...09-sp1-ep.aspx
Setting Up New Enterprise Portal Servers in new Ax installation
1. Install Dynamics AX 2009 AOS and Client
a. Do not install EP during this step.
2. Complete the Initialization Checklist.
3. Run the SP1 patch on the AOS and Client.
4. Complete the Update Checklist. Now the AOS is ready with SP1.
5. Now Install Enterprise Portal and create EP Sites on the EP Server using Ax Setup. ( Make sure all the X++ classes are successfully compiled in a machine where .NET BC is installed, before starting EP deployment)
6. Run SP1 patch on every EP Server
Setting Up New Enterprise Portal Servers in existing Dynamics AX 2009 RTM installation ( but EP was not deployed before)
1. Run the SP1 patch on the AOS and Client
2. Complete the Update Checklist
3. Now Install Enterprise Portal and create EP Sites on the EP Server using Ax Setup. ( Make sure all the X++ classes are successfully compiled in a machine where .NET BC is installed, before starting EP deployment)
4. Run SP1 patch on every EP Server
Upgrading from Dynamics AX 2009 RTM Enterprise Portal Server/Site to Dynamics AX 2009 SP1 ( EP was deployed and sites have been created in Ax 2009 RTM)
3. Run the SP1 patch on every EP Server.( Make sure all the X++ classes are successfully compiled in a machine where .NET BC is installed, before starting EP deployment)
4. Redeploy EP Components to every EP Server by running the below command
a. Run the following from a command prompt:
AxUpdatePortal –iisreset –verbose >>”C:\EPUpdate.log”
ax2009, enterprise portal
Solutions Monkey: Microsoft Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks – 3 Blog bot DAX Blogs 0 27.10.2008 08:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 2 Blog bot DAX Blogs 0 30.09.2008 07:07
Solutions Monkey: Using Microsoft Dynamics Ax 2009 Workflow controls in EP Blog bot DAX Blogs 0 30.07.2008 10:05
Solutions Monkey: Microsofty Dynamics AX 2009 Enterprise Portal / Role Centers - Deployment Tips-n-Tricks - 1 Blog bot DAX Blogs 0 26.06.2008 09:05
Часовой пояс GMT +3, время: 06:53.
