15.05.2009, 09:06 | #1 |
Microsoft Dynamics CRM Team Blog: Update Rollup 4 for Microsoft Dynamics CRM 4.0
Источник: http://blogs.msdn.com/crm/archive/20...s-crm-4-0.aspx
============== The Microsoft Dynamics CRM Sustained Engineering team released Microsoft Dynamics CRM 4.0 Update Rollup 4 on Thursday, May 7, 2009. Below are the links to the release and related information about the Rollup. Please see the Knowledge Base (KB) article for more details about the Update Rollup 4 content and instructions.
Making Update Rollup 4 available to your clients via AutoUpdate You can find more information about AutoUpdate in Eric Newell’s blog entry at http://blogs.msdn.com/crm/archive/20...utoupdate.aspx and the Microsoft Dynamics CRM 4.0 Operating and Maintaining Guide, part of the Microsoft Dynamics CRM 4.0 Implementation Guide. If you have a direct internet connection from your client machines, you can avoid some of the configuration steps and use the LinkId directly. Below are the necessary steps to configure the AutoUpdate for Update Rollup 4. Note: These are steps 5, 6 and 7 of Eric’s blog. Steps for the English version of the product The PatchId and LinkId values will be different for every localized version of CRM 4.0. The IDs can be found in the KB article at http://support.microsoft.com/?kbid=968176. 1. Create the configuration XML file and save it.1: 2: 3: 4: 5: </span> 6: {004A7E60-5DB7-4F05-B7C1-1D2DD653A1A6} 7: Update Rollup 4 for Microsoft Dynamics CRM 4.0 (KB 968176) 8: Update Rollup 4 for Microsoft Dynamics CRM 4.0 (KB 961768) 9: 10: true 11: true 12: OutlookLaptop, OutlookDesktop 13: </span> 14: 15: 150735&clcid=0x409 16: 17: 18: 2. From the command prompt, go to the directory where the ClientPatchConfigurator.exe is located ([ServerInstallDir]\Tools and type microsoft.crm.tools.clientpatchconfigurator.exe [configfile].xmlThe dialog should now appear saying that “Update Rollup 4 for Microsoft Dynamics CRM 4.0 (KB 968176)” is available. If the is set to false, the client will only see the update if the user selects “Check for Updates” via the CRM Menu in the Outlook client. Cheers, Matt Brown Link and Patch IDs for Update Rollup 4 are now part of the KB article. Please see http://support.microsoft.com/?kbid=968176 for more details. Источник: http://blogs.msdn.com/crm/archive/20...s-crm-4-0.aspx
Опции просмотра | |
