#1 |
Kashperuk Ivan: Run AX as a different user from Windows Explorer
Источник: http://kashperuk.blogspot.com/2010/0...m-windows.html
============== This is something useful for people who have already switched to Windows Server 2008 or Windows Vista / Windows 7. As you have probably noticed, the Run as... command is not available in these versions of Windows any longer (it's still available from command line, of course, but that's not as user friendly). As AX users/developers/etc., we all ofter have to log into AX as a different user, for example to verify security settings for a particular AX role being setup. Having Run as... command in the context menu really saves time here. So, Microsoft, namely Mark Russinovich, provided a way to return this useful command back into the standard context menu. You can download and install ShellRunas from technet. Now, to install it, simply follow the easy instructions below:
To uninstall the Shellrunas utility, simply execute the following command from a command prompt: shellrunas /unreg Источник: http://kashperuk.blogspot.com/2010/0...m-windows.html
Опции просмотра | |
