26.10.2011, 09:11 | #1 |
Microsoft Dynamics CRM Team Blog: Update Rollup 5 for Microsoft Dynamics CRM 2011
Источник: http://blogs.msdn.com/b/crm/archive/...-crm-2011.aspx
============== The Microsoft Dynamics CRM Sustained Engineering (SE) team released Microsoft Dynamics CRM 2011 Update Rollup 5 on Tuesday, October 25, 2011. The links below point to important information about Update Rollup 5:
The resources available at these links will be active according to the following Release Channel Schedule:
Update Rollup 6 is to be delivered on its predefined schedule, 16 weeks after Update Rollup 4, which puts the delivery in January 2012. Support for Update Rollup 5 For support on Update Rollup 5, please contact Microsoft Product Support. Note: In special cases, charges ordinarily incurred for support calls may be canceled if a Microsoft Support Professional determines that a specific update will resolve your problem. The usual support costs will apply to additional support questions and issues that do not qualify for the specific update in question. For a complete list of Microsoft Product Support Services telephone numbers and information about support costs, visit the following Microsoft Support web site at: http://support.microsoft.com/default.aspx?scid=fh;[LN];CNTACTMS. Cheers, Matt Brown Источник: http://blogs.msdn.com/b/crm/archive/...-crm-2011.aspx
27.10.2011, 11:11 | #2 |
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 5
Источник: http://blogs.msdn.com/b/crminthefiel...-rollup-5.aspx
============== We're proud to announce that Microsoft Dynamics CRM 2011 Update Rollup 5 released Tuesday Oct. 25th, 2011! On Wednesday Oct. 26th, 2011 at 8 AM Pacific Daylight Time, Greg Nichols and Ryan Anderson from the Microsoft Premier Field Engineering team provided information about the recent release of Update Rollup 5 for Microsoft Dynamics CRM 2011. They also briefly discussed the upcoming release of Update Rollup 20 for Microsoft Dynamics CRM 4.0 during their: Microsoft Dynamics CRM 2011 Update Rollup 5 Podcast Related links you should know about:
5.0.9688.1533 Note: Update Rollup 5 cannot be uninstalled. Specific database updates are applied during Update Rollup 5 installation that will not let you uninstall Update Rollup 5. You should back up your databases and application servers before you install this update. Note: Update Rollup 5 also contains the Dynamics CRM Q4 Service Update features. Some of these features include:
Microsoft Dynamics CRM 2011 Update Rollup 5 is the fifth of a series of cumulative Update Rollups that include fixes for the issues that are or will be documented in the "Master Knowledge Base Articles" for CRM 2011 Update Rollups. As they are cumulative, Update Rollup 5 will contain all fixes shipped via Update Rollups 1-5. Hotfixes and updates that were released as individual fixes The following issues were fixed and delivered to requesting customers prior to Update Rollup 5 release as Critical On Demand (COD) fixes:
Occasionally, updates released via Update Rollups require manual configuration to enable them. Microsoft Dynamics CRM Update Rollups are always cumulative; for example, Update Rollup 5 contains all fixes previously released via Update Rollups 1-4 as well as fixes newly released via Update Rollup 5. So if you install Update Rollup 5 on a machine upon which you previously installed no Update Rollups, you will need to manually enable any desired fixes for Update Rollups 1-5: CRM 2011:
Mismatched Update Rollup versions within a Microsoft Dynamics CRM deployment In a scenario where you may be running many client workstations with Microsoft Dynamics CRM 2011 for Microsoft Office Outlook, a common question is whether it is supported to run mismatched versions. For example, where Update Rollup 5 has been installed on the CRM Server but the Outlook clients are still on Update Rollup 1, or where Update Rollup 1 is on the CRM server but due to updates available to the Outlook client you have decided to install Update Rollup 5 on the clients without installing Update Rollup 4 on the server. The general rule of thumb is to try to keep the versions in sync as much as possible. However, it is permissible (though not recommended as a long-term solution) to run mismatched Update Rollup versions on Outlook client and server, as Microsoft does do some testing of such combinations. However, regarding the other Update Rollups (for example Rollups for the Microsoft Dynamics CRM 2011 Email Router or Microsoft Dynamics CRM 2011 Reporting Extensions), it is not supported nor recommended to run mismatched versions. A best practice is to update these components at the same time you update your CRM Server. Do the best you can to keep these Update Rollup versions in sync. Internet Explorer 9 Compatibility The Microsoft Dynamics CRM Sustained Engineering team extensively tested Microsoft Dynamics CRM 2011 against pre-release versions of Internet Explorer 9 and continues to address compatibility issues, as appropriate, against the RTW (Released to Web) version of Internet Explorer 9. When necessary, Microsoft plans to release enhancements via future Microsoft Dynamics CRM 2011 Update Rollups to assure compatibility with Internet Explorer 9. There are no Internet Explorer - CRM 2011 application compatibility fixes released via Update Rollup 5 specific to Internet Explorer 9. There is a Update Rollup 5 fix for an expanding memory footprint issue associated with Internet Explorer, but it impacts all versions of Internet Explorer supported by CRM 2011 - those being Internet Explorer versions 7, 8, and 9. Источник: http://blogs.msdn.com/b/crminthefiel...-rollup-5.aspx
27.10.2011, 17:11 | #3 |
Microsoft CRM: rollup update 5 for crm 2011
Источник: http://microsoftcrm3.blogspot.com/20...-crm-2011.html
============== Источник: http://microsoftcrm3.blogspot.com/20...-crm-2011.html
Опции просмотра | |
