30.11.2011, 10:11 | #1 |
daxdilip: Tip - How to write to utf-8 encoding format using CommaTextIo Class
Источник: http://feedproxy.google.com/~r/blogs...-encoding.html
============== A few months back, I had written a basic post on How to export csv data from AX using CommaTextIO Class Now, we had a requirement to output the file in utf-8 encoding format and the credit for this post goes to Super Mario (Read below to find who Super Mario is ;-) ..) for his tip which I'm sharing with you all. Tip/Solution: The UTF-8 encoding was achieved by using an additional parameter while calling the constructor for CommaTextIO class.The 3rd(optional) parameter is the codepage integer value. It was achieved as per below: Код: commaTextIo = new CommaTextIo(fileitemdata,#io_write, 65001); What's interesting in Dynamics AX 2012 for UTF-8: I was curious to know how UTF-8 is implemented in the new version of Dynamics AX 2012 and did a search at the AOT Level, found that now we have a placeholder for UTF-8 format in AOT > Macros > File I compared the File Macro in AX 2009 and AX 2012, in AX 2009 there’s no macro for utf-8 but in AX 2012, we have a declaration for it in Macros > File Код: /* UTF-8 Format */ #define.utf8Format (65001) X++: public void sendTo_file(Editor e) { Filename filename; TextIo io; int i = strFind(e.path(), '\\', strLen(e.path()), -strLen(e.path())); str defaultName = subStr(e.path(), i+1, strLen(e.path())); ; filename = WinAPI::getSaveFileName(0, ['Text','*.txt'], '', "@SYS56237", 'txt', defaultName ); if (filename) { // BP deviation documented io = new TextIo(filename, 'W', 65001); // Write the file in UTF8 io.write(EditorScripts::getSelectedText(e)); } } Код: /* UTF Encoding Format */ #define.utf7Format (65000) #define.utf8Format (65001) #define.utf16Format (1200) #define.utf32format (12000) #define.usascii (20127) http://msdn.microsoft.com/en-us/libr...56(VS.85).aspx Ok Ok... I know you have reached here and still wondering who is Super Mario .. :-) He's my boss who is a techie himself. :-) Источник: http://feedproxy.google.com/~r/blogs...-encoding.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 30.11.2011 в 10:23. |
За это сообщение автора поблагодарили: Russland (2). |
Опции просмотра | |
