21.09.2015, 19:11 | #1 |
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3
Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
============== Applies to AX 2012 R2 & AX 2012 R3 Consider the following scenario: When a form is created in e.g. AX 2012 RTM or AX 2012 R2 and a ManagedHost control is added on its design, like "Microsoft.Dynamics.AX.Framework.Client.Controls.ChartToolBar". Then when the form is deployed on a newer AX version, e.g. AX 2012 R3 environment, the form no longer opens but throws the following exception: Could not load file or assembly 'Microsoft.Dynamics.AX.Framework.Client.Controls, Version=6.2.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040) To resolve the above addressed issue, please do as follows: Adding new assembly bindings into Ax32.exe.config to redirect 6.0.0.0 and 6.2.0.0 references to 6.3.0.0 assembly. Here is what precisely you need to do: -Shutdown your AX client -Find the “Ax32.exe.config” file under your Client\Bin directory, normally under “C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin” -Edit the file in Notepad and add the following assembly binding (Highlighted in yellow). -Save the file, but please make sure to keep it in the original format -Start AX client and try your scenario The Ax32.exe.config file content will look like the following after the changes: Источник: http://blogs.msdn.com/b/axsupport/ar...x-2012-r3.aspx
Опции просмотра | |
