#1 |
Setting up delegation and SPNs for NAV 2009 on three machines (when the NAV Server and SQL Server are on two seperate machines) is described in "Walkthrough: Installing the Three Tiers on Three Computers". But in addition to this, also be aware of the following:
Syntax of SPNs has changed since KB 968189 After installing KB 968189 for NAV 2009 (Build 6.0.28795.0) the SPNs now have this format: <Instance>/<server host>:<port> <Instance>/<server FQDN>:<port> So for example if the SPNs used to be set like this: NAV-SERVER_DynamicsNAV/NAV-SERVER.Domain.com:7046 NAV-SERVER_DynamicsNAV/NAV-SERVER:7046 From this build and later they have to be set like this: DynamicsNAV/NAV-SERVER.Domain.com:7046 DynamicsNAV/NAV-SERVER:7046 About KB 968189 itself, it solves a very specific problem where it may not be possible to connect if the domain has multiple DNS Suffixes, which is quite unusual. Most installations are not affected by this. You can check whether you are affected by running ipconfig from a command prompt, and see if it lists more than one domain name under "Connection-specific DNS Suffix". Setting UserAccountControl flag In some cases you have to set UserAccountControl as described in KB 305144. You set this flag by running ADSIEDIT.msc, go to properties of the user account running your NAV Server, and then select UserAccountControl. Setting it to 17301504 means TRUSTED_FOR_DELEGATION+TRUSTED_TO_AUTH_FOR_DELEGATION
