#1 |
Hi Everybody!
I was playing around with the new RTC over WAN feature in NAV 2009 R2. Basically I was following the instructions on the MSDN website you can find on http://msdn.microsoft.com/en-us/library/gg502478.aspx The reason for this is that I want to know HOW it works, and also the performance will be. Of course this is only a hyper v server image running on a test environment you will not have a real performance. But anyway, for me and I think for a lot of other people this is “good enough” to evaluate when it could make sense working with it. Regarding to this points I thought you could be interested in trying it by yourself without installing your own server. Because of this I will give you my configuration data and credentials and so you are “only” need a RTC to try it by yourself. But sorry guys – I need the the resources on this machine ![]() ![]() 1. Download the files 2. Install both certificates (these are test certificates built by HOW TO from MSDN) (Right mouse click – install certificate – select store automatically) 3. Backup your existing UserSettings.config file. 4. Replace the existing one with the one from your downloaded files 5. Start the RTC 6. Login by using contosoadministrator – pass@word1 ![]() Language English and German is available. Regards, Rene PS would be great if you write comments on this post if you get experience with it. Далее
