18.12.2007, 19:50 | #1 |
Arijit Basu: Multiple AOS in a Multi CPU Machine :)
Источник: http://daxguy.blogspot.com/2007/12/m...u-machine.html
============== You are all aware that presently AX AOS does not support more that 2 processors. Now say you have a multi processor Box where you want to install multiple AOS and make sure that each AOS Service points to a specific processor. Follow the steps: 1.Open Task Manager 2.Right Click on AX32Serv.exe 3.Click "Set Affinity" 4.A window opens up which shows all the CPU's your Box has 5.You can now , for each AOS Service point/ check the CPU's you want to run on :) But the limitation is that when you restart the service/ Box , you must do this again. Also if the AOS Service runs under local/system/network Account, you cannot do this. Only available for AD accounts. This is NOT recommended in a live environment. Happy DAX-ing Источник: http://daxguy.blogspot.com/2007/12/m...u-machine.html
19.12.2007, 17:11 | #2 |
