04.08.2008, 03:16 | #1 |
C# and AX Development: AX Database Performance
Источник: http://olondono.blogspot.com/2008/08...rformance.html
============== Here is an excellent post about AX database performance applying a checking list: http://blogs.msdn.com/axperf/archive...st-part-1.aspx Some tips: - Max Degree of Parallelism (MAXDOP instance-wide) - OLTP (normal operations0: Set Max Degree of Parallelism to 1) - Upgrade: set to # of physical processor cores, ... - Activate AWE only for 32-bits systems - Separate log and data files - Configure several temp DBs - Set Read-Committed Snapshot Isolation = true ALTER DATABASE SET READ_COMMITTED_SNAPSHOT ON; - Physical storage configuration (RAID, separate logs and data files, etc.) Источник: http://olondono.blogspot.com/2008/08...rformance.html
