#1 |
hi guys,
I have a problem when I insert record into table from outside of AX, can I do insert() method on axapta? I want to check something on insert() method, can I ? any solutions? thanks (sorry, my english is bad ![]()
some thing big is won't be a big thing, if you don't know a little thing ![]() |
#2 |
And in case you mean you insert a new record via a direct SQL connection to an AX database the answer is: stop doing this immediately and use AX Business Connector instead. |
