27.12.2008, 17:05 | #1 |
Arijit Basu: Installing AX 2009 Reporting Extensions in MSSQL 2008 & WIN 2008
Источник: http://daxguy.blogspot.com/2008/12/i...xtensions.html
============== When we try to install AX 2009 SP1 Reporting Services on a PC running SQL 2008,we get an error saying that MSSQL 2005 SP2 is required. Well there is a solution to this issue which is as follows: 1. Locate the AX Reporting services dll from the extracted AX 2009 SP1 folder [\\AX2009SP1\support\axsetupresources\microsoft.dynamics.setup.reportingservices.dll;File Version - 5.0.1000.52] 2. Extract the AX 2009 .iso to a shared folder 3. Copy the microsoft.dynamics.setup.reportingservices.dll into the folder: \\DynamicsAX\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Setup \\DynamicsAX\Msi\Components64\Program Files\Microsoft Dynamics AX\50\Setup 4. It will ask to replace the existing dll having File Version - 5.0.593.0. Say Yes and replace. 5. Then Install AX Reporting Services extensions. It works fine and the Reporting Extensions are installed nice. Источник: http://daxguy.blogspot.com/2008/12/i...xtensions.html
